Dear akohlmey,
Thank you for your response.
The LAMMPS version is “LAMMPS 64-bit 10Mar2021”. The workstation that I am using is based on two processors with;
Processor Intel(R) Xeon(R) Gold 6148 CPU @ 2.40GHz, 2394 Mhz, 20 Core(s), 40 Logical Processor(s)
Below is the input script for my HybridFF MD simulation.
REAXff - MFI type ZTC
-------------------- Init Section ----------------------
units real
atom_style full
pair_style hybrid/overlay reax/c NULL checkqeq no lj/cut/coul/long 12
kspace_style ewald 1.0e-5
-------------------- Atom Definition Section ------------
read_data Cathode-min.data
#change_box all x final 0 20 y final 0 20 z final 0 20
Li-air battery electrolyte
group dmso molecule 1 # density is 1.0956 g/cm3
group Li molecule 2
group salt molecule 3
Cathode structure
group C molecule 4 # Zeolite templated carbon structure
Reactants for electrochemical reaction
group oxygen molecule 5
#--------------------- Pair Coefficients ------------------------
pair_coeff * * reax/c ffield.reax_mf.LIS NULL NULL NULL NULL Li NULL NULL C O NULL
Lennard jonnes parameters
pair_coeff 1 1 lj/cut/coul/long 0.1200 3.4000 # O(dmso)-O(dmso) LJ
pair_coeff 1 2 lj/cut/coul/long 0.2049 3.7000 # O(dmso)-S(dmso) LJ
pair_coeff 1 3 lj/cut/coul/long 0.0967 3.7400 # O(dmso)-C(dmso) LJ
pair_coeff 1 4 lj/cut/coul/long 0.0537 3.0400 # H(dmso)-O(dmso) LJ
pair_coeff 1 5 lj/cut/coul/long 0.1112 2.4212 # O(dmso)-Li+ LJ
pair_coeff 1 6 lj/cut/coul/long 0.1257 3.5475 # O(dmso)-P(pf6) LJ
pair_coeff 1 7 lj/cut/coul/long 0.0587 3.1674 # O(dmso)-F(pf6) LJ
pair_coeff 1 8 lj/cut/coul/long 0.0817 3.4000 # O(dmso)-C(ztc) LJ
pair_coeff 1 9 lj/cut/coul/long 0.1121 3.3485 # O(dmso)-O2 LJ
pair_coeff 1 10 lj/cut/coul/long 0.0000 1.7000 # O(dmso)-H(ztc) LJ
pair_coeff 2 2 lj/cut/coul/long 0.3500 4.0000 # S(dmso)-S(dmso) LJ
pair_coeff 2 3 lj/cut/coul/long 0.1652 4.0400 # S(dmso)-C(dmso) LJ
pair_coeff 2 4 lj/cut/coul/long 0.0916 3.3400 # S(dmso)-H(dmso) LJ
pair_coeff 2 5 lj/cut/coul/long 0.1899 2.7212 # S(dmso)-Li+ LJ
pair_coeff 2 6 lj/cut/coul/long 0.2147 3.8475 # S(dmso)-P(pf6) LJ
pair_coeff 2 7 lj/cut/coul/long 0.1002 3.4674 # S(dmso)-F(pf6) LJ
pair_coeff 2 8 lj/cut/coul/long 0.1395 3.7000 # S(dmso)-C (ztc) LJ
pair_coeff 2 9 lj/cut/coul/long 0.1914 3.6485 # S(dmso)-O2 LJ
pair_coeff 2 10 lj/cut/coul/long 0.0000 2.0000 # S(dmso)-H(ztc) LJ
pair_coeff 3 3 lj/cut/coul/long 0.0780 4.0800 # C(dmso)-C(dmso) LJ
pair_coeff 3 4 lj/cut/coul/long 0.0433 3.3800 # C(dmso)-H(dmso) LJ
pair_coeff 3 5 lj/cut/coul/long 0.0897 2.7612 # C(dmso)-Li+ LJ
pair_coeff 3 6 lj/cut/coul/long 0.1013 3.8875 # C(dmso)-P(pf6) LJ
pair_coeff 3 7 lj/cut/coul/long 0.0473 3.5074 # C(dmso)-F(pf6) LJ
pair_coeff 3 8 lj/cut/coul/long 0.0658 3.7400 # C(dmso)-C(ztc) LJ
pair_coeff 3 9 lj/cut/coul/long 0.0904 3.6885 # C(dmso)-O2 LJ
pair_coeff 3 10 lj/cut/coul/long 0.0000 2.0400 # C(dmso)-H(ztc) LJ
pair_coeff 4 4 lj/cut/coul/long 0.0240 2.6800 # H(dmso)-H(dmso) LJ
pair_coeff 4 5 lj/cut/coul/long 0.0498 2.0612 # H(dmso)-Li+ LJ
pair_coeff 4 6 lj/cut/coul/long 0.0562 3.1875 # H(dmso)-P(pf6) LJ
pair_coeff 4 7 lj/cut/coul/long 0.0262 2.8074 # H(dmso)-F(pf6) LJ
pair_coeff 4 8 lj/cut/coul/long 0.0365 3.0400 # H(dmso)-C(ztc) LJ
pair_coeff 4 9 lj/cut/coul/long 0.0501 2.9885 # H(dmso)-O2 LJ
pair_coeff 4 10 lj/cut/coul/long 0.0000 1.3400 # H(dmso)-H(ztc) LJ
#pair_coeff 5 5 lj/cut/coul/long 0.0000 1.4424 # Li±Li+ LJ
pair_coeff 5 6 lj/cut/coul/long 0.1165 2.5687 # Li±P(pf6) LJ
pair_coeff 5 7 lj/cut/coul/long 0.0544 2.1885 # Li±F(pf6) LJ
#pair_coeff 5 8 lj/cut/coul/long 0.0000 2.4212 # Li±C(ztc) LJ
#pair_coeff 5 9 lj/cut/coul/long 0.0000 2.3697 # Li±O2 LJ
pair_coeff 5 10 lj/cut/coul/long 0.0000 0.7212 # Li±H(ztc) LJ
pair_coeff 6 6 lj/cut/coul/long 0.1317 3.6950 # P(pf6)-P(pf6) LJ
pair_coeff 6 7 lj/cut/coul/long 0.0287 3.3148 # P(pf6)-F(pf6) LJ
pair_coeff 6 8 lj/cut/coul/long 0.0856 3.5475 # P(pf6)-C(ztc) LJ
pair_coeff 6 9 lj/cut/coul/long 0.1174 3.4960 # P(pf6)-O2 LJ
pair_coeff 6 10 lj/cut/coul/long 0.0000 1.8475 # P(pf6)-H(ztc) LJ
pair_coeff 7 7 lj/cut/coul/long 0.0287 2.9347 # F(pf6)-F(pf6) LJ
pair_coeff 7 8 lj/cut/coul/long 0.0399 3.1674 # F(pf6)-C(ztc) LJ
pair_coeff 7 9 lj/cut/coul/long 0.0548 3.1158 # F(pf6)-O2 LJ
pair_coeff 7 10 lj/cut/coul/long 0.0000 1.4674 # F(pf6)-H(ztc) LJ
#pair_coeff 8 8 lj/cut/coul/long 0.0000 3.4000 # C(ztc)-C(ztc) LJ
#pair_coeff 8 9 lj/cut/coul/long 0.0000 3.3485 # C(ztc)-O2 LJ
pair_coeff 8 10 lj/cut/coul/long 0.0000 1.7000 # C(ztc)-H (ztc) LJ
#pair_coeff 9 9 lj/cut/coul/long 0.0000 3.2970 # O2-O2 LJ
pair_coeff 9 10 lj/cut/coul/long 0.0000 1.6485 # O2-H(ztc) LJ
pair_coeff 10 10 lj/cut/coul/long 0.0000 0.0000 # H(ztc)-H(ztc) LJ
-------------------- Settings Section -------------------
neighbor 1 bin
neigh_modify every 1 delay 0 check no
timestep 0.01
fix 2 all qeq/reax 1 0.0 10.0 1e-4 reax/c
fix rffbonds all reax/c/bonds 100 Cathode.bonds
velocity dmso create 300 4928459 dist gaussian
velocity salt create 300 4928459 dist gaussian
velocity Li create 300 4928459 dist gaussian
velocity oxygen create 300 4928459 dist gaussian
-------------------- Run Section (NVT: density)------------------
fix 1 C rigid group 1 C reinit yes
fix C C setforce 0.0 0.0 0.0
fix 3 dmso nvt temp 300.0 300.0 10
fix 4 salt nvt temp 300.0 300.0 10
fix 5 Li nvt temp 300.0 300.0 10
fix 6 oxygen nvt temp 300.0 300.0 10
-------------------- MSD Section -------------------
compute msdelec dmso msd com yes
compute msdpf6 salt msd com yes
compute msdli Li msd com yes
compute msdo2 oxygen msd com yes
fix msdelec dmso ave/time 100 10 1000 c_msdelec[1] c_msdelec[2] c_msdelec[3] c_msdelec[4] file elec.msd
fix msdpf6 salt ave/time 100 10 1000 c_msdpf6[1] c_msdpf6[2] c_msdpf6[3] c_msdpf6[4] file pf6.msd
fix msdli Li ave/time 100 10 1000 c_msdli[1] c_msdli[2] c_msdli[3] c_msdli[4] file Li.msd
fix msdo2 oxygen ave/time 100 10 1000 c_msdo2[1] c_msdo2[2] c_msdo2[3] c_msdo2[4] file O2.msd
-------------------- Concentration Section -------------------
compute elec dmso chunk/atom bin/1d z lower 2.0
compute pf6 salt chunk/atom bin/1d z lower 2.0
compute lithium Li chunk/atom bin/1d z lower 2.0
compute o2 oxygen chunk/atom bin/1d z lower 2.0
fix 8 dmso ave/chunk 100 10 1000 elec density/mass density/number c_elec ave running file density_elec.out
fix 9 salt ave/chunk 100 10 1000 pf6 density/mass density/number c_pf6 ave running file density_pf6.out
fix 10 Li ave/chunk 100 10 1000 lithium density/mass density/number c_lithium ave running file density_lithium.out
fix 11 oxygen ave/chunk 100 10 1000 o2 density/mass density/number c_o2 ave running file density_o2.out
-------------------- Simulation data settings ------------------------
dump 1 all atom 100 Cathode.dump
dump_modify 1 scale no image yes
dump 2 all custom 100 Cathode.veldump vx vy vz
dump 3 all atom 1000 MD4-NVT*.lammpstrj
compute reax all pair reax/c
variable rffeb equal c_reax[1]
variable rffea equal c_reax[2]
variable rffelp equal c_reax[3]
variable rffemol equal c_reax[4]
variable rffev equal c_reax[5]
variable rffepen equal c_reax[6]
variable rffecoa equal c_reax[7]
variable rffehb equal c_reax[8]
variable rffet equal c_reax[9]
variable rffeco equal c_reax[10]
variable rffew equal c_reax[11]
variable rffep equal c_reax[12]
variable rffefi equal c_reax[13]
variable rffeqeq equal c_reax[14]
thermo 100
thermo_style custom etotal ke pe v_rffeb v_rffea v_rffelp v_rffev v_rffepen v_rffecoa v_rffet v_rffew v_rffep elong v_rffeqeq v_rffehb temp press
thermo_modify line multi
thermo_modify flush yes
restart 30000 MD.restart
run 40000
write_data Cathode-MD1.data
Regards
Khizar
