I get the Worker was sent SIGKILL! Perhaps out of memory?
I tried upgrading the memory to 16GB. Still I get the same error.
I have 4 CPU cores in my machine.
I don’t think that memory is a problem, because in a different VM instance, I was able to run using 8GB.
Can anyone tell if this is really a RAM not sufficient issue or something else. What I can do to debug this? Any help on this matter is greatly appreciated.
Some relevant docs and system status are shown below:
[ec-sherinsu@u-geovis01 nomad-oasis]$ docker logs nomad_oasis_app
[2025-01-14 12:55:42 +0000] [7] [INFO] Starting gunicorn 21.2.0
[2025-01-14 12:55:42 +0000] [7] [INFO] Listening at: http://0.0.0.0:8000 (7)
[2025-01-14 12:55:42 +0000] [7] [INFO] Using worker: uvicorn.workers.UvicornWorker
[2025-01-14 12:55:42 +0000] [23] [INFO] Booting worker with pid: 23
[2025-01-14 12:55:42 +0000] [24] [INFO] Booting worker with pid: 24
[2025-01-14 12:55:42 +0000] [25] [INFO] Booting worker with pid: 25
[2025-01-14 12:55:43 +0000] [26] [INFO] Booting worker with pid: 26
[2025-01-14 13:05:43 +0000] [7] [CRITICAL] WORKER TIMEOUT (pid:23)
[2025-01-14 13:05:43 +0000] [7] [CRITICAL] WORKER TIMEOUT (pid:24)
[2025-01-14 13:05:43 +0000] [7] [CRITICAL] WORKER TIMEOUT (pid:25)
[2025-01-14 13:05:43 +0000] [7] [CRITICAL] WORKER TIMEOUT (pid:26)
[2025-01-14 13:05:44 +0000] [7] [ERROR] Worker (pid:26) was sent SIGKILL! Perhaps out of memory?
[2025-01-14 13:05:44 +0000] [7] [ERROR] Worker (pid:24) was sent SIGKILL! Perhaps out of memory?
[2025-01-14 13:05:44 +0000] [222] [INFO] Booting worker with pid: 222
[2025-01-14 13:05:44 +0000] [7] [ERROR] Worker (pid:23) was sent SIGKILL! Perhaps out of memory?
[2025-01-14 13:05:44 +0000] [7] [ERROR] Worker (pid:25) was sent SIGKILL! Perhaps out of memory?
[2025-01-14 13:05:44 +0000] [223] [INFO] Booting worker with pid: 223
[2025-01-14 13:05:44 +0000] [224] [INFO] Booting worker with pid: 224
[2025-01-14 13:05:44 +0000] [225] [INFO] Booting worker with pid: 225
[2025-01-14 13:19:09 +0000] [7] [INFO] Starting gunicorn 21.2.0
[2025-01-14 13:19:09 +0000] [7] [INFO] Listening at: http://0.0.0.0:8000 (7)
[2025-01-14 13:19:09 +0000] [7] [INFO] Using worker: uvicorn.workers.UvicornWorker
[2025-01-14 13:19:09 +0000] [18] [INFO] Booting worker with pid: 18
[ec-sherinsu@u-geovis01 nomad-oasis]$ pwd
/home/ec-sherinsu/nomad-oasis
[ec-sherinsu@u-geovis01 nomad-oasis]$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 3.8G 0 3.8G 0% /dev
tmpfs 3.8G 0 3.8G 0% /dev/shm
tmpfs 3.8G 1.6M 3.8G 1% /run
tmpfs 3.8G 0 3.8G 0% /sys/fs/cgroup
/dev/mapper/internvg-root 8.0G 446M 7.6G 6% /
/dev/mapper/internvg-usr 12G 8.7G 3.4G 73% /usr
/dev/mapper/internvg-tmp 4.0G 61M 4.0G 2% /tmp
/dev/mapper/internvg-opt 4.0G 72M 4.0G 2% /opt
/dev/sda1 507M 391M 117M 78% /boot
/dev/mapper/internvg-var 8.0G 2.8G 5.3G 35% /var
tmpfs 1.6G 0 1.6G 0% /run/user/2100510
[ec-sherinsu@u-geovis01 nomad-oasis]$ df -h /home
Console output from a different attempt
[ec-sherinsu@u-geovis01 nomad-oasis]$ sudo docker compose up -d
WARN[0000] The "PWD" variable is not set. Defaulting to a blank string.
[+] Running 6/6
✔ Container nomad_oasis_elastic Healthy 0.5s
✔ Container nomad_oasis_rabbitmq Healthy 0.5s
✔ Container nomad_oasis_mongo Healthy 0.5s
✔ Container nomad_oasis_north Healthy 1.0s
✔ Container nomad_oasis_worker Running 0.0s
✘ Container nomad_oasis_app Error 1.0s
dependency failed to start: container nomad_oasis_app is unhealthy
[2025-01-14 13:48:16 +0000] [7] [INFO] Starting gunicorn 21.2.0
[2025-01-14 13:48:16 +0000] [7] [INFO] Listening at: http://0.0.0.0:8000 (7)
[2025-01-14 13:48:16 +0000] [7] [INFO] Using worker: uvicorn.workers.UvicornWorker
[2025-01-14 13:48:16 +0000] [24] [INFO] Booting worker with pid: 24
[2025-01-14 13:48:17 +0000] [25] [INFO] Booting worker with pid: 25
[2025-01-14 13:48:17 +0000] [26] [INFO] Booting worker with pid: 26
[2025-01-14 13:48:17 +0000] [27] [INFO] Booting worker with pid: 27
[2025-01-14 13:58:17 +0000] [7] [CRITICAL] WORKER TIMEOUT (pid:24)
[2025-01-14 13:58:17 +0000] [7] [CRITICAL] WORKER TIMEOUT (pid:25)
[2025-01-14 13:58:17 +0000] [7] [CRITICAL] WORKER TIMEOUT (pid:26)
[2025-01-14 13:58:17 +0000] [7] [CRITICAL] WORKER TIMEOUT (pid:27)
[2025-01-14 13:58:18 +0000] [7] [ERROR] Worker (pid:26) was sent SIGKILL! Perhaps out of memory?
[2025-01-14 13:58:18 +0000] [7] [ERROR] Worker (pid:25) was sent SIGKILL! Perhaps out of memory?
[2025-01-14 13:58:18 +0000] [221] [INFO] Booting worker with pid: 221
[2025-01-14 13:58:18 +0000] [7] [ERROR] Worker (pid:24) was sent SIGKILL! Perhaps out of memory?
[2025-01-14 13:58:18 +0000] [7] [ERROR] Worker (pid:27) was sent SIGKILL! Perhaps out of memory?
[2025-01-14 13:58:18 +0000] [222] [INFO] Booting worker with pid: 222
[2025-01-14 13:58:18 +0000] [223] [INFO] Booting worker with pid: 223
[2025-01-14 13:58:18 +0000] [224] [INFO] Booting worker with pid: 224
