Hello ,
first off ,thanks for creating atomate …I would like to use MITRelaxSet and wanted to modify Incar parameters ISPIN to 3 and add KPAR = 1…i have used the following code…
from fireworks import Workflow
from atomate.vasp.fireworks.core import OptimizeFW
from pymatgen.io.vasp.sets import MITRelaxSet
from pymatgen import Structure
from fireworks import LaunchPad
def get_optimize_wf(structure, name="optimization wf", vasp_input_set=None,
tag="", metadata=None):
# Structure optimization firework
fws = [OptimizeFW(structure=structure, vasp_input_set = vasp_input_set,
name="{} structure optimization".format(tag))]
wfname = "{}:{}".format(structure.composition.reduced_formula, name)
return Workflow(fws, name=wfname, metadata=metadata)
#load your structure, e.g. from a POSCAR
struct = Structure.from_file('POSCAR')
# create a custom input set
my_custom_input_set = MITRelaxSet(struct)
print('Before change: {}'.format(my_custom_input_set._config_dict["INCAR"]))
my_custom_input_set._config_dict["INCAR"].update({"ISPIN":3,"KPAR":1})
print('After change: {}'.format(my_custom_input_set._config_dict["INCAR"]))
# create the workflow
my_wf = get_optimize_wf(struct, vasp_input_set = my_custom_input_set)
lpad = LaunchPad.auto_load() # loads this based on the FireWorks configuration
lpad.add_wf(my_wf)
I could successfully print the applied incar parameters …but unable to actually pass those parameters in the calculation…It is still using the predefined incar…and i don’t know whether i’ve written the correct code …so please check and I am unable to properly paste the code here so correct indentations before copying the code and trying it out.
P.S : I have successfully run the calculations using user_incar_settings …but i wanted to try this way using config_dict …help is much appreciated
