I am a beginner to LAMMPS and trying to understand a result from compute group/group. I am a bit confused about the sign of the energy.
System details
Two graphene sheets (parallel plates)
Each sheet has 416 carbon atoms
Partial charge per carbon atom: ±0.002403846 e
- So each sheet carries approximately ±1e total charge
Simulation box dimensions:
( x = 32.08 , Å )
( y = 34.19 , Å )
( z = 35.5 , Å )
Units:
real -
Long-range electrostatics:
kspace_style pppm -
kspace slab 3.0
What I did
I defined groups:
solute1→ lower graphene sheet -
solute2→ upper graphene sheet
Then computed:
compute A1A1 solute1 group/group solute1 kspace yesThis gives the electrostatic interaction energy of the graphene sheet with itself.
Observation
The value I obtain is:
A11 ≈ −3.27 kcal/mol -
My expectation
Since all atoms in a graphene sheet have the same sign of charge, I expected:
Coulomb interaction between atoms → repulsive
Therefore:[U > 0]My current understanding (please confirm/correct)
From my analysis, LAMMPS (via PPPM/Ewald) computes:
[U = U_real + U_kspace + U_self + U_background
U_real: pairwise Coulomb (positive for like charges)
U_kspace: long-range contribution
U_self: self-energy correction (negative)
U_background: neutralizing background (negative if net charge ≠ 0)
Since the graphene sheet has net charge ≈ +1e, a uniform neutralizing background is introduced, which contributes a negative energy.
QUE
- Is the negative value mainly coming from the background and self-energy terms?
- More generally, how should I interpret the sign of this group/group electrostatic energy? Does a negative value here really indicate net attraction, or is the sign dominated by Ewald/PPPM corrections rather than simple pairwise interactions?
- Does
compute group/groupinclude these contributions even when looking at a single group? - Is it correct to say that this A1A1 value is not just “repulsion between atoms,” but includes Ewald-related corrections?
- If I want the physically intuitive repulsive interaction within the sheet, is there a better way to compute it?
