I’m just starting out with LAMMPS, but eventually I’ll need to make a potential somewhat similar to lj/cut/tip4p/long. For now, I’m just trying to understand exactly what pair_lj_cut_tip4p_long.cpp does.
I would be very grateful if someone could answer some (or all!) of my questions.
Before I get to my questions, I will briefly summarize my understanding of what’s going on just to make sure I’m even at the point of knowing what I’m asking.
For a parallel calculation, atoms are assigned to a particular processor. The neighbours of this atom may, or may not, be assigned to the same processor – if not, they are referred to as ghost atoms. Ghost atom positions are updated after they move, and the identities of ghost atoms are updated whenever neighbour lists are updated. Bonded neighbors are usually not included in the neighbour list of a given atom, although presumably bonded atoms will usually be assigned to the same processor (I think not necessarily?). In the TIP4P model, information about bonded hydrogen atoms is required to calculate the position of the negative charge site, which is located off of the oxygen atom. So, when looping over atom pairs, if one of the atoms is identified as oxygen, the index numbers of the bonded hydrogen atoms are obtained using:
hneigh[j][0] = jH1 = atom->map(atom->tag[j] + 1);
hneigh[j][1] = jH2 = atom->map(atom->tag[j] + 2);
Since there is a “+1” or “+2” in the above lines, atoms in the input data file must be ordered with oxygen first, then the two H atoms. If you wanted to, for whatever reason, have the hydrogen atoms listed first, and the oxygen atom listed last, you would have to change the above code to -1 (or -2) - is that correct?
Does atom->map(atom->tag[j] + 1) get the correct index number for the hydrogen atom whether the hydrogen atom is a ghost atom or not? My understanding is that the hydrogen atom does not need to be a ghost atom or an owned atom for the mapping to be correct - am I right?
I think the line hneigh[j][2] = 1; just indicates that the index numbers associated with the hydrogen atoms bonded to the jth oxygen atom are already known, and don’t need to be gotten with atom->map(atom->tag[j] + 1) again (until the positions change)?
The positions of owned and ghost atoms are already passed through the neighbour list (I’m sure I didn’t say that correctly, hopefully my meaning is clear) such that the minimum distance between the atoms is obtained when calculating, for example, delx = x[j][0] - xtmp;. Since the bonded hydrogen atoms obtained through the mapping described above might not be either ghost or owned atoms,
domain->minimum_image(delx1,dely1,delz1);
is used when calcuating the position of the charge site. Have I understood this correctly (I think minimum images are already handled properly by the neighbour lists for ghost and owned atoms)?
I have more questions, but this email is already too long. I have been printing things out to try to get a handle on everything, but I’m just not sure I’ve understood properly. I would really appreciate any help.
Cheers,
Jeff
