Hi all,
I’m seeing some behavior from FireWorks that I don’t understand, and I’m hoping that someone can help me out. This is an issue that I’ve never encountered when using atomate, but now I’m seeing it regularly with a different, stand-alone installation of FireWorks. The basic problem is that using lpad add in the command line will not only add the specified workflow, but also seems to run any python scripts in directories where I’ve run workflows before.
I have a developer installation (version 2.0.3) and I can reproduce the issue reliably with the included tutorials. If I run the “firetask” tutorial with the python interface, everything works normally:
from fireworks import Firework, FWorker, LaunchPad
from fireworks.core.rocket_launcher import launch_rocket
from fw_tutorials.firetask.addition_task import AdditionTask
launchpad = LaunchPad(host = myHost, ..., etc.)
firework = Firework(AdditionTask(), spec={"input_array": [1, 2]})
launchpad.add_wf(firework)
launch_rocket(launchpad, FWorker())
Now suppose that I replace the entire contents of that file (call it addition.py) with
print("The quick brown fox jumped over the lazy dog")
Just for good measure, I also rename the file to some_other_name.py and run lpad_reset. Then I pop over into the “introduction” directory and attempt to run that tutorial through the command line:
ebanyas@cori08:~/software/fireworks/fw_tutorials/introduction> lpad add fw_test.yaml
2022-07-15 13:03:52,542 INFO Added a workflow. id_map: {-1: 1}
The script ../firetask/some_other_name.py is being executed by lpad add, and I can’t figure out how to prevent this from happening. Maybe it’s a bug… or maybe this is normal behavior and I’m just missing something obvious? Thank you in advance!
