CLASSIFICATION: UNCLASSIFIED
I'm trying to debug a complicated simulation and have created the following reduced testcase:
----BEGIN FILE---
units lj
atom_style atomic
lattice fcc 0.8442
region box block 0 4 0 4 0 4
create_box 1 box
create_atoms 1 box
mass 1 1.0
velocity all create 0.1 87287
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
neigh_modify every 1 delay 0 check no
#fix 1 all nvt temp 0.1 0.8 1.0
fix 1 all npt temp 0.1 0.8 1.0 iso 0.0 0.0 10.0
#fix 1 all nve
dump 1 all custom 1000 dump.melt.* id type xs ys zs
dump_modify 1 sort id
run 1000
unfix 1
#fix 1 all nvt temp 0.8 0.8 1.0
fix 1 all npt temp 0.8 0.8 1.0 iso 0.0 0.0 10.0
#fix 1 all nve
run 1000
write_restart tmp.restart.*
run 4000
clear
read_restart tmp.restart.2000
#fix 1 all nve
dump 1 all custom 1000 dump.meltR.* id type xs ys zs
run 4000
---END FILE---
The input creates a simple crystal lattice of Lennard-Jones particles, runs for 1000 steps heating them up, runs for another 1000 steps at constant T, writes a restart file, runs for 4000 steps, clears the simulation, reads the restart, re-fixes NPT, and runs for another 4000 steps. It makes some dumps along the way. Neighbor lists are rebuilt every single time step. I ran this with both the latest stable lammps (June 2019) and a February 2018 version. 'make serial' in either case, RHEL7 machine, gcc.
My expectation is that at timestep 6000, the files dump.melt.6000 and dump.meltR.6000 will be identical. Yet, they are not. On my system, I see a difference (in box dimensions) at the step 4000 dump files, and many various differences in the step 6000 dump files. If I use the commented-out fix nvt or nve in place of all the npt fixes, then, the step 6000 dump files are identical. If I use fix npt in each place, but comment out the two neigh_modify commands, then the results at step 6000 are identical. A significantly shorter test case does not show the same error -- a certain # of time steps (or perhaps neighbor builds...) need to occur before the two series of dump files show a difference. Appending "start 1000 stop 6000 pre no" to the last 3 run commands does not result in the step 6000 dump files being identical.
I'm wondering, what is the cause of the observed difference between the original run and the restarted run, and can it be fixed? My understanding (and my limited inspection of fix_nh.cpp) is that the restart should pick up the internal state of the thermostat/barostat from the restart file, given the same fix #. And, fix nvt works fine. I tried tinkering with some fix npt options but none had an effect on the example problem. Is it perhaps related to how the simulation cell dimensions are stored in the restart file? That would surprise me, I guess, but I'm having a hard time seeing why fix nvt would not display this issue, but fix npt would (if the barostat internal variables are being restarted as anticipated). I searched the lammps-users archives but did not quickly find something with a use case identical to what I'm describing above (the most relevant thread was wanting to continue a single run with changing temperature).
Brian
