Hello, Lammps community.
I hope to perform a polarizable water simulation using the Drude package. When I tried to run the example case swm4 coming with the Drude package, I noticed something unusual:
If I use the Langevin thermostat (see in.swm4-ndp.lang in the example), the reported temperature of the Drude particle is 1.99K, almost twice the target value. However, if I use the Nose-Hoover thermostat (in.swm4-ndp.nh in the example), the reported temperature is 1K, as expected.
Has anyone experienced a similar problem? Is there a way to fix this or am I making some mistake?
Thank you very much for your time!
