I have conversion ratio as
Temperature T* T* X 2.5173 x 10^4 K
Length r* r* x 0.20951 nm
(sigma = 0.20951 nm)
Mass M M* x 28.06
Time t* t* x 7.66 x 10^-14 s
t* x 7.66 x 10^-5 ns
Diffusion coefficient
D* Dsigma^2/tau = D x .005730345 cm^2/s
Density rho* rho* x 0.1087391 atoms/Angstrom^3
rho* x 5.0517 gm/cm^3
in unit lj lammps script is
#script for lj potential
#—initialization—
units lj
atom_style atomic
lattice fcc 0.3
region box block 0 5 0 5 0 5
create_box 1 box
create_atoms 1 box
mass 1 1.0
velocity all create 1.0 45454
#—system potential—
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
neighbor 0.3 bin
#—variables—
compute myTemp all temp
compute myVir all pressure myTemp
variable curstep equal step
variable curT equal temp
variable curP equal (c_myVir[1]+c_myVir[2]+c_myVir[3])/3.0
variable curPE equal pe
variable curKE equal ke
variable curE equal etotal
variable curV equal vol
variable curH equal enthalpy
thermo_style custom step temp press pe ke etotal vol enthalpy
thermo 100
fix myData all print 1 “{curstep} {curT} {curP} {curPE} {curKE} {curE} {curV} {curH}” screen no file ljReduced1.dat title “#Step Temp Pres PE KE TotlE Vol Enthalpy”
#—run—
timestep 0.005
fix 1 all nvt temp 1.0 1.0 1.0
run 5000
And in metal unit after multiplying conversion ratio lammps script
#—initialization—
atom_style atomic
lattice fcc 1.46457
variable lencon equal 2.0951
variable engcon equal 2.1683
variable timeCon equal 0.005*7.53e-14
region box block 0 10.4755 0 10.4755 0 10.4755
create_box 1 box
create_atoms 1 box
mass 1 28.06
velocity all create 25163 454543
#—system potential—
pair_style lj/cut 5.23775
pair_coeff 1 1 2.0951 2.1683 5.23775
neighbor 0.62853 bin
#—variables—
thermo 100
fix myData all print 1 “{curstep} {curT} {curP} {curPE} {curKE} {curE} {curV} {curH}” screen no file ljMetal1.dat title “#Step Temp Pres PE KE TotlE Vol Enthalpy”
#—run—
timestep 7.53e-14
fix 1 all nvt temp 25163.0 25163.0 1.0
run 5000
But both results are far from equal ,These conversion ratios are correct for silicon.
