Hi fellow users, I received this error when trying to run lammps .
unknown identifier in data file: C -0.20275 36.13264 -0.0000
Below and attached is my model made using crystal maker.
model.xyz (6.1 KB)
model.xyz (6.1 KB)
How are you trying to load this into LAMMPS?
If you're just using the read_data command, LAMMPS won't understand xyz input. You need to give it a data file in the format explained on the manual page (http://lammps.sandia.gov/doc/read_data.html)
