My group has predicted several new stable compounds for different crystal systems.
I want to contribute this data to MP. I wonder how the MP-ID is assigned to the structures and how detailed information is required to be uploaded.
Hi @Davit_Gochitashvili, the MP-ID is assigned internally as part of our core data processing pipelines. Did you use VASP to calculate these structures? If so, and if your calculations are compatible with MP’s, we might be able to incorporate your structures into our core data (with appropriate credit of course).
Thank you for a quick reply.
Yes, we used VASP for calculations. So Composition and CIF file should be enough or more information is needed or the website will automatically parse out information form the CIF files?
Ok, great. Let’s check first whether your calculations happen to be compatible with MP. @Aaron_Kaplan would be able to point you to documentation on how to go about it.
Hey @Davit_Gochitashvili, we check compatibility of the calculation settings, especially the pseudpotentials / POTCARs, used in a calculation. You can test our new validation software by running pip install pymatgen-io-validation, and then run
from pymatgen.io.validation import ValidationDoc
valid_doc = ValidationDoc.from_directory("path to your VASP calc")
print(valid_doc.valid)
Any reasons for validation failure will be contained in valid_doc.reasons, and any warnings in valid_doc.warnings
Sounds good! Feel free to use a string for the identifier field in MPContribs that makes sense to you internally. How many structures are you planning to upload? Please let me know once you’re done with it. We’ll take a look at them and decide whether we’d also like to get your raw VASP directories to include them into our core dataset. Thanks!
Thank you for the feedback.
Okay, I will use more sensible names for the IDs.
There should be around 10 structures that are stable at ambient conditions (0 GPa and 0K).
I am planning to upload predicted structures from our other published studies as well, but I will register those as separate projects.
I need to prepare data to upload. It might take some time. I will let you know once I finish.
I noticed that all structures on MP have electronic structure information listed, like band gap. I wonder if I need to include that data to my contributions.
You don’t need to but please feel free to add any additional data to the data component in MPContribs that you think might be interesting for general MP users to know. Once we take your original structures and add them to our core set of materials, their properties such as bandgaps will be calculated automatically (and will hopefully be the same as in your MPContribs project).
Hello @Aaron_Kaplan,
I was trying to use pymatgen.io.validation for the layered structures calculated using optb86b-vdw. In reasons I received this error message: ['NO MATCHING MP INPUT SET --> no matching MP input set was found. If you believe this to be a mistake, please create a GitHub issue.']
Could you please give information what functionals are valid for the calculations including Van der Waals interactions?
Hi @Davit_Gochitashvili, we don’t use vdW corrections in MP’s core calculations currently. It’s obviously needed for many materials, but would also require development of another “compatibility” scheme to align the thermodynamic convex hulls of a vdW-corrected and uncorrected functional
If the goal is to contribute calculations to MP, I would strongly recommend using either our workflow orchestration tool atomate2 - examples and explanation here - or the pre-defined VASP input sets from pymatgen:
MPRelaxSet: PBE or PBE+U (for transition-metal oxides)
MPScanRelaxSet: r2SCAN meta-GGA calculations
Alternatively, you can submit structures and we’ll run them when we get a chance!
I finally managed to upload Pd-Sn structures that are on the convex hull of stability at ambient conditions (0 GPa and 0K).
The project is called “SnCompounds”.
Please let me know if there is any additional information needed to make these structures available publicly.
Thank you!
Thanks @Davit_Gochitashvili! Looks good! I just approved your project. Please feel free to use client.make_public() anytime to publish your project. @Aaron_Kaplan and @tsmathis can then take the structures and shepherd them through our production for an upcoming data release.
I have 2 new structure CIF files that I’d like to submit for calculation and inclusion in the Materials Project database. The structures come from a relevant publication on oxyhalide Li SSEs that would enrich MP by their inclusion. I don’t think this is a big enough project for an MPContribs, and I think these 2 structures should be included in the MP dataset so that Phase Diagrams include these phases, the Reaction Calculator can calculate reactions in light of the phases, and so on. It looks like submission of new structures is no longer supported. Please consider either accepting private submissions or re-opening API support, or submission on your Materials Project Crystal Toolkit.
Hey @bayesfactor, due to software license issues, we can’t directly perform calculations on structures submitted by the community. However we are working to support submission of complete calculations by the community
If the structures are published in the article you linked, then I can add them to the batch of structures currently being computed
