While using coord/atom
as
compute coord all coord/atom cutoff 1.0
dump d1 all custom 10 coords.dat c_coord
or
compute coord all coord/atom cutoff 1.0 *
it throws an error.
ERROR: Expected floating point parameter in input script or data file (…/compute_coord_atom.cpp:40)
May I know where I’m going wrong?
as
or
it throws an error.
(../compute_coord_atom.cpp:40)
May I know where I'm going wrong?
are you looking at the documentation that matches your LAMMPS version?
Yes, I’m using the right documentation. I’m currently using the stable 17-Nov-16. version.
(Thank you, Axel for pointing out that I’m not following the etiquette.)
Yes, I'm using the right documentation. I'm currently using the stable
17-Nov-16. version.
this cannot be, since the syntax you are using is only correct for LAMMPS
version 17 Jan 2017 and later.
this is mentioned in the change log:
http://lammps.sandia.gov/bug.html
