I've been preparing some GPU-accelerated simulations today, and I get
the error that USER-CUDA requires a CUDA variant of min_style cg (or
whichever minimization style I wished to use). This poses several
questions:
(1) Is it even possible to do a minimization when the USER-CUDA package
is active?
(2) Are there any CUDA-compatible minimization styles (it doesn't look
like it), and if not, will there ever be any?
(3) Is it possible to turn off the USER-CUDA functionality during the
minimization step, then turn it back on once that's over?
The last one I'm sure is wishful thinking, but I thought I'd ask.
It might be possible to use fix nve/limit (without using the GPU for that
part of the calculation) to do what the minimization would have been
doing. I would use the GPU package, which seems to be OK with
minimizations, but that is incompatible with pair styles tersoff and
tersoff/zbl (the GPU package requires the newton pair flag to be off,
whereas tersoff requires it to be on).
Suggestions are welcome.
Karl D. Hammond
University of Tennessee, Knoxville
[email protected]...
"You can never know everything, and part of what you know is always
wrong. A portion of wisdom lies in knowing that. A portion of courage
lies in going on anyway."
"Nothing ever goes as you expect. Expect nothing, and you will not be
surprised."
questions:
is active?
not via the minimize command, but you could do simulated annealing
using fix viscous or a temperature ramp. both of which as supported by
USER-CUDA, if i remember correctly.
no and probably no. USER-CUDA is currently (mostly) unmaintained.
christian is working full time on the KOKKOS package, which promises
to use a more futureproof and portable approach to accelerators.
no. but it would be trivial to run two inputs and avoid compatibility
clashes by using write_data/read_data to start from it.
newton pair is not the issue, but the fact that there is no tersoff/gpu style.
