Please always include the mailing list in recipients.
I don’t find anything obviously wrong with your input. However, I used different data and potential files, since you didn’t attach yours. Add “echo both” to the script in order to check at which command the simulation fails.
Michal
I don't find anything obviously wrong with your input. However, I used different data and potential files, since you didn't attach yours. Add "echo both" to the script in order to check at which command the simulation fails.
more importantly: does it run without crashing, when you *don't* use
the -sf intel flag?
