Hi!
When using 'intel' styles from the USER-INTEL package, the default 'mode', is
'mixed', meaning that:
calculations between pairs or triplets of atoms are performed in single
precision, intended to be within the inherent error of MD simulations. All
accumulation is performed in double precision to prevent the error from
growing with the number of atoms in the simulation.
(LAMMPS Molecular Dynamics Simulator)
How does one decide when it is okay to use the default, and when to use
'double'?
I assume that in cases where an energy minimisation occurs, it would make
sense to calculate forces at a higher precision.
What other situations is this advisible for?
Thanks!
Vishnu
Hi!
When using ‘intel’ styles from the USER-INTEL package, the default ‘mode’, is
‘mixed’, meaning that:
(https://lammps.sandia.gov/doc/Speed_intel.html)
‘double’?
no. it has little to do with this.
computing forces in single precision is acceptable, when sufficient error cancellation happens, e.g. when you compute forces in a homogeneous system and when the system is small enough, that the loss of precision when representing atoms far away from the origin does not matter much. also for computing pressure, since stress converges less well than forces with respect to the correctness of the potential function and particularly variable cell calculation, using double precision is advisable.
there are differing opinions about what accuracy and what degree of error cancellation is acceptable, so don’t expect that what one person recommends will be ok with another.
My systems are fairly homogenous and isotropic in particle density, and have
~100K atoms. Also, the force cut-off is such that each particle has upto about
12 neighbours (this can go upto about 25 for some models I use).
also for
I will keep that in mind, if I need to compute stresses and pressures.
cancellation is acceptable, so don't expect that what one person recommends
Yes, but exactly what measure(s) does one use, to decide?
