parth@Assistant:/mnt/c/Users/parth/lammps-29Aug2024/src$ make yes-USER-MISC
Package USER-MISC does not exist
make: *** [Makefile:605: yes-USER-MISC] Error 1
I am facing this error.
my lammps version is 29Aug2024 stable version. And I am installing it on Ubuntu LTS 22.04.
Thanks a lot akohlmey. I could finally run lammps.
One more issue that concerns me here is, I have to run gcmc in my code but when I use lmp_mpi -in in.water it works well but when I run with the command lmp -in in.water, it shows the following error
ERROR: Unrecognized fix style ‘gcmc’ is part of the MC package which is not enabled in this LAMMPS binary. (src/modify.cpp:924)
Last command: fix all water gcmc 100 100 10 0 1235896 300.15 -0.5 0.01 mol 99 pressure 6.0
As a beginner, I have read the documentation and trying to figure out the error.
It would be great if someone gives a brief explanation of how this works and why the error is happening.
I am unable to comprehend the error message.
As I already mentioned the error doesn’t arise when I use the command
But it only comes when I use
lmp -in in.water.
And I have checked the MC Package is installed and I can access it through the lmp_mpi command but not with lmp command. So, it clearly shows that gcmc is both installed and enabled.
I doubt that that is a correct assessment.
Please run lmp -h and lmp_mpi -h and check the output.
Then you are in big trouble.
The explanation I can provide is exactly what is written in the manual and what common sense dictates. I don’t have the time or interest to spoon-feed you. That is outside the scope of this forum.
If this was a more complex and obscure error, I would be willing (and then in the process figure out a way to make the message more obvious), but not for something as obvious as this one.
