I am running a PIM-1 polymer simulation with water both side on it. There is also graphene wall both side on the water chamber to create a pressure of 1 bar on each wall so that the water can insert into the polymer. In a NVT simulation, to create the 1 bar pressure on the wall , I am using the addforce command( fix 1 wall1 addforce 0.0 0.0 3.5633e-5) and I have calculated the force for the wall in real unit 3.5633e-5 Kcal/mol-angstrom ( as I have 540 atoms in the each graphene wall and the wall area is 36.27 x 36.86 (angstrom)^2).
However, after running for almost 1 ns the water become utterly compressed and so the polymer as you can see from the picture. It is not supposed to be compressed in only 1 bar pressure. I am looking for suggestion if I am doing it correct for creating the pressure using the addforce command ?
For your reference, I have equilibrated both the water and the polymer without adding any pressure & ensured that both of them have meet the correct density before applying the pressure. My lammps version is 21November 2023.
Regards,
Morshed Mahmud
Ph.D. Student
Rennes Institute of chemical science , France
