using fireworks with python3 : use of basestring
I’m running fireworks with python3 since my code is written in python3 (I’m a newbie in the python world, so I have started with the last version).
Everything runs fine, but I ran into a problem by accident (running qlaunch on a system with no queue system) :
File “/usr/lib/python3.4/site-packages/fireworks/user_objects/queue_adapters/common_adapter.py”, line 194, in submit_to_queue
p = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
File “/usr/lib64/python3.4/subprocess.py”, line 859, in init
restore_signals, start_new_session)
File “/usr/lib64/python3.4/subprocess.py”, line 1457, in _execute_child
raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: ‘sbatch’
During handling of the above exception, another exception occurred:
File “/usr/lib/python3.4/site-packages/fireworks/queue/queue_launcher.py”, line 124, in launch_rocket_to_queue
reservation_id = qadapter.submit_to_queue(SUBMIT_SCRIPT_NAME)
File “/usr/lib/python3.4/site-packages/fireworks/user_objects/queue_adapters/common_adapter.py”, line 222, in submit_to_queue
.format(submit_cmd))
File “/usr/lib/python3.4/site-packages/fireworks/utilities/fw_utilities.py”, line 118, in log_exception
return log_fancy(m_logger, msgs, ‘error’, add_traceback=True)
File “/usr/lib/python3.4/site-packages/fireworks/utilities/fw_utilities.py”, line 97, in log_fancy
if isinstance(msgs, basestring):
NameError: name ‘basestring’ is not defined
File “/usr/bin/qlaunch”, line 6, in
qlaunch()
File “/usr/lib/python3.4/site-packages/fireworks/scripts/qlaunch_run.py”, line 173, in qlaunch
do_launch(args)
File “/usr/lib/python3.4/site-packages/fireworks/scripts/qlaunch_run.py”, line 55, in do_launch
args.launch_dir, args.reserve, args.loglvl, False)
File “/usr/lib/python3.4/site-packages/fireworks/queue/queue_launcher.py”, line 132, in launch_rocket_to_queue
log_exception(l_logger, ‘Error writing/submitting queue script!’)
type basestring no more exists in python3. I have found 2 uses of basestring in fireworks
grep basestring (find /lib/python3.4/site-packages/fireworks/ -type f -name ‘*.py’)
/lib/python3.4/site-packages/fireworks/queue/queue_adapter.py: if isinstance(command, basestring):
/lib/python3.4/site-packages/fireworks/utilities/fw_utilities.py: if isinstance(msgs, basestring):
Maybe You could fix this to improve compatibility with python3 ?
Cheers,
David
Hi David
Thanks for reporting this. The basestring should have been fixed very recently in the latest release (v1.3.6).
Anubhav
On Wednesday, September 7, 2016 at 6:44:14 AM UTC-7, [email protected] wrote:
qlaunch()
do_launch(args)
Cheers,
David
