for a research project i have to simulate particle breaking into given number of sub particles with co ordinates within the Big sphere which breaks and the voids present between it and neighbouring atoms.
I went through the lammps site and i used the make mode=shlib ubuntu command .This produces lot of warnings in between.But still it compiles and produces a ‘share library soft link liblammps.so’.
However i dont know how to proceed in linking this library as when i put
$make install
or $sudo make install
after make mode command it doesnt work.And when i use the ./configure command
in my ubuntu 14.04 it says command doesnt exist.
Also i used the $export ADD_LIBRARY_PATH command but nothing works.
So how do i link the library to my c++ code.
Also can any function directly pack spheres even in voids along with main major space and give info on neighbouring atoms.
pS REPLY AS SOON AS POSSIBLE.
thank you
bhavana
mechanical engineering
indian institute of information technology,design and manufacturing
