I just created an empty conda environment, did a clean clone of FireWorks, and python setup.py develop
Here is the full detailed inputs and outputs. Note that the first time I ran your script, it was as-is and producing the errors, the second time is after removing those first two lines.
computron-7:~ ajain$ mkdir test_fws
computron-7:~ ajain$ cd test_fws/
computron-7:test_fws ajain$ cp …/test_wf.py .
computron-7:test_fws ajain$ conda create --name fws_test_env python=3.7
Solving environment: done
Package Plan
environment location: /Users/ajain/miniconda3/envs/fws_test_env
added / updated specs:
The following packages will be downloaded:
package | build
python-3.7.2 | haf84260_0 21.6 MB
libedit-3.1.20181209 | hb402a30_0 159 KB
ca-certificates-2018.12.5 | 0 123 KB
Total: 21.9 MB
The following NEW packages will be INSTALLED:
ca-certificates: 2018.12.5-0
certifi: 2018.11.29-py37_0
libcxx: 4.0.1-hcfea43d_1
libcxxabi: 4.0.1-hcfea43d_1
libedit: 3.1.20181209-hb402a30_0
libffi: 3.2.1-h475c297_4
ncurses: 6.1-h0a44026_1
openssl: 1.1.1a-h1de35cc_0
pip: 18.1-py37_0
python: 3.7.2-haf84260_0
readline: 7.0-h1de35cc_5
setuptools: 40.6.3-py37_0
sqlite: 3.26.0-ha441bb4_0
tk: 8.6.8-ha441bb4_0
wheel: 0.32.3-py37_0
xz: 5.2.4-h1de35cc_4
zlib: 1.2.11-h1de35cc_3
Proceed ([y]/n)? y
Downloading and Extracting Packages
python-3.7.2 | 21.6 MB | ############################################################################# | 100%
libedit-3.1.20181209 | 159 KB | ############################################################################# | 100%
ca-certificates-2018 | 123 KB | ############################################################################# | 100%
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
To activate this environment, use
$ conda activate fws_test_env
To deactivate an active environment, use
$ conda deactivate
computron-7:test_fws ajain$ conda activate fws_test_env
(fws_test_env) computron-7:test_fws ajain$ git clone [email protected]:materialsproject/fireworks.git
Cloning into ‘fireworks’…
remote: Enumerating objects: 360, done.
remote: Counting objects: 100% (360/360), done.
remote: Compressing objects: 100% (153/153), done.
remote: Total 23630 (delta 277), reused 249 (delta 207), pack-reused 23270
Receiving objects: 100% (23630/23630), 18.02 MiB | 8.16 MiB/s, done.
Resolving deltas: 100% (16863/16863), done.
(fws_test_env) computron-7:test_fws ajain$ cd fireworks/
(fws_test_env) computron-7:fireworks ajain$ python setup.py develop
running develop
running egg_info
creating FireWorks.egg-info
writing FireWorks.egg-info/PKG-INFO
writing dependency_links to FireWorks.egg-info/dependency_links.txt
writing entry points to FireWorks.egg-info/entry_points.txt
writing requirements to FireWorks.egg-info/requires.txt
writing top-level names to FireWorks.egg-info/top_level.txt
writing manifest file ‘FireWorks.egg-info/SOURCES.txt’
reading manifest file ‘FireWorks.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
warning: no previously-included files matching ‘*.pyc’ found under directory ‘fireworks’
warning: no previously-included files matching ‘*.pyc’ found under directory ‘docs’
warning: no previously-included files matching ‘*.pyc’ found under directory ‘fw_tutorials’
running build_ext
Creating /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/FireWorks.egg-link (link to .)
Adding FireWorks 1.8.4 to easy-install.pth file
Installing lpad script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installing mlaunch script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installing qlaunch script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installing rlaunch script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installed /Users/ajain/test_fws/fireworks
Processing dependencies for FireWorks==1.8.4
Searching for tqdm>=4.8.4
Reading https://pypi.org/simple/tqdm/
Downloading https://files.pythonhosted.org/packages/ed/d6/3458d39cf4978f4ece846295e83daf5ece710ab0a4106774f7f7b3a68697/tqdm-4.29.1-py2.py3-none-any.whl#sha256=c9b9b5eeba13994a4c266aae7eef7aeeb0ba2973e431027e942b4faea139ef49
Best match: tqdm 4.29.1
Processing tqdm-4.29.1-py2.py3-none-any.whl
Installing tqdm-4.29.1-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
Adding tqdm 4.29.1 to easy-install.pth file
Installing tqdm script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/tqdm-4.29.1-py3.7.egg
Searching for gunicorn>=19.6.0
Reading https://pypi.org/simple/gunicorn/
Downloading https://files.pythonhosted.org/packages/8c/da/b8dd8deb741bff556db53902d4706774c8e1e67265f69528c14c003644e6/gunicorn-19.9.0-py2.py3-none-any.whl#sha256=aa8e0b40b4157b36a5df5e599f45c9c76d6af43845ba3b3b0efe2c70473c2471
Best match: gunicorn 19.9.0
Processing gunicorn-19.9.0-py2.py3-none-any.whl
Installing gunicorn-19.9.0-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
writing requirements to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/gunicorn-19.9.0-py3.7.egg/EGG-INFO/requires.txt
Adding gunicorn 19.9.0 to easy-install.pth file
Installing gunicorn script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installing gunicorn_paster script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/gunicorn-19.9.0-py3.7.egg
Searching for flask-paginate>=0.4.5
Reading https://pypi.org/simple/flask-paginate/
Downloading https://files.pythonhosted.org/packages/fc/95/d7d61640893050a55365ffba33885883495c0838a05f11984336aa023f00/flask-paginate-0.5.1.tar.gz#sha256=b68e8d7664419ad53728514139811bce9c3f2e56199a6c057ef4c08f9f35f35d
Best match: flask-paginate 0.5.1
Processing flask-paginate-0.5.1.tar.gz
Writing /var/folders/90/ntqv188927lgzsjpt6f_p4_80000gn/T/easy_install-xjc7w6qh/flask-paginate-0.5.1/setup.cfg
Running flask-paginate-0.5.1/setup.py -q bdist_egg --dist-dir /var/folders/90/ntqv188927lgzsjpt6f_p4_80000gn/T/easy_install-xjc7w6qh/flask-paginate-0.5.1/egg-dist-tmp-qd21e8my
creating /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/flask_paginate-0.5.1-py3.7.egg
Extracting flask_paginate-0.5.1-py3.7.egg to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
Adding flask-paginate 0.5.1 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/flask_paginate-0.5.1-py3.7.egg
Searching for flask>=0.11.1
Reading https://pypi.org/simple/flask/
Downloading https://files.pythonhosted.org/packages/7f/e7/08578774ed4536d3242b14dacb4696386634607af824ea997202cd0edb4b/Flask-1.0.2-py2.py3-none-any.whl#sha256=a080b744b7e345ccfcbc77954861cb05b3c63786e93f2b3875e0913d44b43f05
Best match: Flask 1.0.2
Processing Flask-1.0.2-py2.py3-none-any.whl
Installing Flask-1.0.2-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
writing requirements to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/Flask-1.0.2-py3.7.egg/EGG-INFO/requires.txt
Adding Flask 1.0.2 to easy-install.pth file
Installing flask script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/Flask-1.0.2-py3.7.egg
Searching for tabulate>=0.7.5
Reading https://pypi.org/simple/tabulate/
Downloading https://files.pythonhosted.org/packages/12/c2/11d6845db5edf1295bc08b2f488cf5937806586afe42936c3f34c097ebdc/tabulate-0.8.2.tar.gz#sha256=e4ca13f26d0a6be2a2915428dc21e732f1e44dad7f76d7030b2ef1ec251cf7f2
Best match: tabulate 0.8.2
Processing tabulate-0.8.2.tar.gz
Writing /var/folders/90/ntqv188927lgzsjpt6f_p4_80000gn/T/easy_install-1wgdm28h/tabulate-0.8.2/setup.cfg
Running tabulate-0.8.2/setup.py -q bdist_egg --dist-dir /var/folders/90/ntqv188927lgzsjpt6f_p4_80000gn/T/easy_install-1wgdm28h/tabulate-0.8.2/egg-dist-tmp-257z8jrx
zip_safe flag not set; analyzing archive contents…
Copying tabulate-0.8.2-py3.7.egg to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
Adding tabulate 0.8.2 to easy-install.pth file
Installing tabulate script to /Users/ajain/miniconda3/envs/fws_test_env/bin
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/tabulate-0.8.2-py3.7.egg
Searching for python-dateutil>=2.5.3
Reading https://pypi.org/simple/python-dateutil/
Downloading https://files.pythonhosted.org/packages/74/68/d87d9b36af36f44254a8d512cbfc48369103a3b9e474be9bdfe536abfc45/python_dateutil-2.7.5-py2.py3-none-any.whl#sha256=063df5763652e21de43de7d9e00ccf239f953a832941e37be541614732cdfc93
Best match: python-dateutil 2.7.5
Processing python_dateutil-2.7.5-py2.py3-none-any.whl
Installing python_dateutil-2.7.5-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
writing requirements to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/python_dateutil-2.7.5-py3.7.egg/EGG-INFO/requires.txt
Adding python-dateutil 2.7.5 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/python_dateutil-2.7.5-py3.7.egg
Searching for monty>=1.0.1
Reading https://pypi.org/simple/monty/
Downloading https://files.pythonhosted.org/packages/37/32/1766195d89398fa070a5098e462907f31154881d6381746c25b69f1c2fdc/monty-1.0.5-py3-none-any.whl#sha256=e860c905c5e6e3e5c0957e3e0faa983da20c4854c88cd515bb5a4600cd198fa8
Best match: monty 1.0.5
Processing monty-1.0.5-py3-none-any.whl
Installing monty-1.0.5-py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
writing requirements to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/monty-1.0.5-py3.7.egg/EGG-INFO/requires.txt
Adding monty 1.0.5 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/monty-1.0.5-py3.7.egg
Searching for six>=1.10.0
Reading https://pypi.org/simple/six/
Downloading https://files.pythonhosted.org/packages/73/fb/00a976f728d0d1fecfe898238ce23f502a721c0ac0ecfedb80e0d88c64e9/six-1.12.0-py2.py3-none-any.whl#sha256=3350809f0555b11f552448330d0b52d5f24c91a322ea4a15ef22629740f3761c
Best match: six 1.12.0
Processing six-1.12.0-py2.py3-none-any.whl
Installing six-1.12.0-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
Adding six 1.12.0 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/six-1.12.0-py3.7.egg
Searching for Jinja2>=2.8.0
Reading https://pypi.org/simple/Jinja2/
Downloading https://files.pythonhosted.org/packages/7f/ff/ae64bacdfc95f27a016a7bed8e8686763ba4d277a78ca76f32659220a731/Jinja2-2.10-py2.py3-none-any.whl#sha256=74c935a1b8bb9a3947c50a54766a969d4846290e1e788ea44c1392163723c3bd
Best match: Jinja2 2.10
Processing Jinja2-2.10-py2.py3-none-any.whl
Installing Jinja2-2.10-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
writing requirements to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/Jinja2-2.10-py3.7.egg/EGG-INFO/requires.txt
Adding Jinja2 2.10 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/Jinja2-2.10-py3.7.egg
Searching for pymongo>=3.3.0
Reading https://pypi.org/simple/pymongo/
Downloading https://files.pythonhosted.org/packages/d7/ac/d2e324c1f9bcf653fa106785371a16b4709506a35b04948655de8b961a85/pymongo-3.7.2-cp37-cp37m-macosx_10_9_x86_64.whl#sha256=1826527a0b032f6e20e7ac7f72d7c26dd476a5e5aa82c04aa1c7088a59fded7d
Best match: pymongo 3.7.2
Processing pymongo-3.7.2-cp37-cp37m-macosx_10_9_x86_64.whl
Installing pymongo-3.7.2-cp37-cp37m-macosx_10_9_x86_64.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
writing requirements to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/pymongo-3.7.2-py3.7-macosx-10.7-x86_64.egg/EGG-INFO/requires.txt
Adding pymongo 3.7.2 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/pymongo-3.7.2-py3.7-macosx-10.7-x86_64.egg
Searching for ruamel.yaml>=0.15.35
Reading https://pypi.org/simple/ruamel.yaml/
Downloading https://files.pythonhosted.org/packages/43/6e/aa168badc6dc6c2894b5dfec3352d1beed3ecf1f41fab3e1c7fd36b883ca/ruamel.yaml-0.15.87-cp37-cp37m-macosx_10_9_x86_64.whl#sha256=5dd0ea7c5c703e8675f3caf2898a50b4dadaa52838f8e104637a452a05e03030
Best match: ruamel.yaml 0.15.87
Processing ruamel.yaml-0.15.87-cp37-cp37m-macosx_10_9_x86_64.whl
Installing ruamel.yaml-0.15.87-cp37-cp37m-macosx_10_9_x86_64.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
writing requirements to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/ruamel.yaml-0.15.87-py3.7-macosx-10.7-x86_64.egg/EGG-INFO/requires.txt
Adding ruamel.yaml 0.15.87 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/ruamel.yaml-0.15.87-py3.7-macosx-10.7-x86_64.egg
Searching for itsdangerous>=0.24
Reading https://pypi.org/simple/itsdangerous/
Downloading https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl#sha256=b12271b2047cb23eeb98c8b5622e2e5c5e9abd9784a153e9d8ef9cb4dd09d749
Best match: itsdangerous 1.1.0
Processing itsdangerous-1.1.0-py2.py3-none-any.whl
Installing itsdangerous-1.1.0-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
Adding itsdangerous 1.1.0 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/itsdangerous-1.1.0-py3.7.egg
Searching for click>=5.1
Reading https://pypi.org/simple/click/
Downloading https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl#sha256=2335065e6395b9e67ca716de5f7526736bfa6ceead690adf616d925bdc622b13
Best match: Click 7.0
Processing Click-7.0-py2.py3-none-any.whl
Installing Click-7.0-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
Adding Click 7.0 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/Click-7.0-py3.7.egg
Searching for Werkzeug>=0.14
Reading https://pypi.org/simple/Werkzeug/
Downloading https://files.pythonhosted.org/packages/20/c4/12e3e56473e52375aa29c4764e70d1b8f3efa6682bef8d0aae04fe335243/Werkzeug-0.14.1-py2.py3-none-any.whl#sha256=d5da73735293558eb1651ee2fddc4d0dedcfa06538b8813a2e20011583c9e49b
Best match: Werkzeug 0.14.1
Processing Werkzeug-0.14.1-py2.py3-none-any.whl
Installing Werkzeug-0.14.1-py2.py3-none-any.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
writing requirements to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/Werkzeug-0.14.1-py3.7.egg/EGG-INFO/requires.txt
Adding Werkzeug 0.14.1 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/Werkzeug-0.14.1-py3.7.egg
Searching for MarkupSafe>=0.23
Reading https://pypi.org/simple/MarkupSafe/
Downloading https://files.pythonhosted.org/packages/96/52/eef455862764cb6d6c136aa52c7f9fc4e7c1c644790a7107b1244a2b8a53/MarkupSafe-1.1.0-cp37-cp37m-macosx_10_6_intel.whl#sha256=1f19ef5d3908110e1e891deefb5586aae1b49a7440db952454b4e281b41620cd
Best match: MarkupSafe 1.1.0
Processing MarkupSafe-1.1.0-cp37-cp37m-macosx_10_6_intel.whl
Installing MarkupSafe-1.1.0-cp37-cp37m-macosx_10_6_intel.whl to /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages
Adding MarkupSafe 1.1.0 to easy-install.pth file
Installed /Users/ajain/miniconda3/envs/fws_test_env/lib/python3.7/site-packages/MarkupSafe-1.1.0-py3.7-macosx-10.7-x86_64.egg
Finished processing dependencies for FireWorks==1.8.4
(fws_test_env) computron-7:fireworks ajain$ cd …
(fws_test_env) computron-7:test_fws ajain$ python test_wf.py
2019-01-24 00:37:32,313 INFO Performing db tune-up
2019-01-24 00:37:32,320 INFO LaunchPad was RESET.
2019-01-24 00:37:32,322 INFO Added a workflow. id_map: {-3: 1, -2: 2, -1: 3}
2019-01-24 00:37:32,501 INFO Created new dir /Users/ajain/test_fws/launcher_2019-01-24-08-37-32-501749
2019-01-24 00:37:32,502 INFO Launching Rocket
2019-01-24 00:37:32,732 INFO RUNNING fw_id: 3 in directory: /Users/ajain/test_fws/launcher_2019-01-24-08-37-32-501749
2019-01-24 00:37:32,740 INFO Task started: ScriptTask.
hello
2019-01-24 00:37:32,748 INFO Task completed: ScriptTask
File “fireworks/fireworks/core/launchpad.py”, line 1467, in _refresh_wf
updated_ids = wf.refresh(fw_id)
File “fireworks/fireworks/core/firework.py”, line 1011, in refresh
updated_ids = updated_ids.union(self.refresh(child_id, updated_ids))
File “fireworks/fireworks/core/firework.py”, line 974, in refresh
if fw.spec.get(’_allow_fizzled_parents’):
File “fireworks/fireworks/core/launchpad.py”, line 1790, in spec
return self.partial_fw.spec
File “fireworks/fireworks/core/launchpad.py”, line 1863, in partial_fw
self._fw = Firework.from_dict(data)
File “fireworks/fireworks/utilities/fw_serializers.py”, line 155, in _decorator
new_args[0] = {k: _recursive_load(v) for k, v in args[0].items()}
File “fireworks/fireworks/utilities/fw_serializers.py”, line 118, in _recursive_load
return {k: _recursive_load(v) for k, v in obj.items()}
File “fireworks/fireworks/utilities/fw_serializers.py”, line 121, in _recursive_load
return [_recursive_load(v) for v in obj]
File “fireworks/fireworks/utilities/fw_serializers.py”, line 113, in _recursive_load
return load_object(obj)
File “fireworks/fireworks/utilities/fw_serializers.py”, line 369, in load_object
raise ValueError(‘load_object() could not find a class with cls._fw_name {}’.format(fw_name))
ValueError: load_object() could not find a class with cls._fw_name PyTask
During handling of the above exception, another exception occurred:
File “fireworks/fireworks/core/rocket.py”, line 357, in run
lp.complete_launch(launch_id, m_action, final_state)
File “fireworks/fireworks/core/launchpad.py”, line 1278, in complete_launch
self._refresh_wf(fw_id)
File “fireworks/fireworks/core/launchpad.py”, line 1482, in _refresh_wf
raise RuntimeError(err_message)
RuntimeError: Error refreshing workflow. The full stack trace is: Traceback (most recent call last):
File “fireworks/fireworks/core/launchpad.py”, line 1468, in _refresh_wf
File “fireworks/fireworks/core/launchpad.py”, line 1508, in _update_wf
File “fireworks/fireworks/core/firework.py”, line 1080, in to_db_dict
File “fireworks/fireworks/core/firework.py”, line 779, in state
File “test_wf.py”, line 18, in
rapidfire(launchpad)
File “fireworks/fireworks/core/rocket_launcher.py”, line 108, in rapidfire
File “fireworks/fireworks/core/rocket_launcher.py”, line 58, in launch_rocket
File “fireworks/fireworks/core/rocket.py”, line 402, in run
self._update_wf(wf, updated_ids)
wf = wf.to_db_dict()
m_dict[‘state’] = self.state
for child_id in self.links[fizzled_id])):
(fws_test_env) computron-7:test_fws ajain$ vi test_wf.py # remove the first two lines of the script
2019-01-24 00:39:41,917 INFO Performing db tune-up
2019-01-24 00:39:41,923 INFO LaunchPad was RESET.
2019-01-24 00:39:41,925 INFO Added a workflow. id_map: {-3: 1, -2: 2, -1: 3}
2019-01-24 00:39:42,007 INFO Created new dir /Users/ajain/test_fws/launcher_2019-01-24-08-39-42-006876
2019-01-24 00:39:42,007 INFO Launching Rocket
2019-01-24 00:39:42,019 INFO RUNNING fw_id: 3 in directory: /Users/ajain/test_fws/launcher_2019-01-24-08-39-42-006876
2019-01-24 00:39:42,024 INFO Task started: ScriptTask.
hello
2019-01-24 00:39:42,028 INFO Task completed: ScriptTask
2019-01-24 00:39:42,049 INFO Rocket finished
2019-01-24 00:39:42,052 INFO Created new dir /Users/ajain/test_fws/launcher_2019-01-24-08-39-42-052138
2019-01-24 00:39:42,052 INFO Launching Rocket
2019-01-24 00:39:42,061 INFO RUNNING fw_id: 1 in directory: /Users/ajain/test_fws/launcher_2019-01-24-08-39-42-052138
2019-01-24 00:39:42,066 INFO Task started: PyTask.
2019-01-24 00:39:47,068 INFO Task completed: PyTask
2019-01-24 00:39:47,080 INFO Rocket finished
2019-01-24 00:39:47,083 INFO Created new dir /Users/ajain/test_fws/launcher_2019-01-24-08-39-47-082953
2019-01-24 00:39:47,083 INFO Launching Rocket
2019-01-24 00:39:47,092 INFO RUNNING fw_id: 2 in directory: /Users/ajain/test_fws/launcher_2019-01-24-08-39-47-082953
2019-01-24 00:39:47,096 INFO Task started: ScriptTask.
goodbye
2019-01-24 00:39:47,100 INFO Task completed: ScriptTask
2019-01-24 00:39:47,111 INFO Rocket finished
On Thu, Jan 24, 2019 at 12:23 AM Leip [email protected] wrote:
I used python setup.py develop
The test seems ok (ran 156 tests, OK (skipped=8)
Le mercredi 23 janvier 2019 10:57:22 UTC+1, Leip a écrit :
I’d like to use PyTask to execute custom functions.
Using the very simple Workflow from the doc, I have this:
~/working$ ls
fireworks test-wf.py
~/working$ cat test-wf.py
import sys
sys.path.insert(0, “fireworks”)
from fireworks import Firework, Workflow, LaunchPad, ScriptTask, PyTask
from fireworks.core.rocket_launcher import rapidfire
set up the LaunchPad and reset it
launchpad = LaunchPad()
launchpad.reset(’’, require_password=False)
create the individual FireWorks and Workflow
fw1 = Firework(ScriptTask.from_str(‘echo hello’), name=“hello”)
fw2 = Firework(ScriptTask.from_str(‘echo goodbye’), name=“goodbye”)
fw_timer = Firework(PyTask(func=‘time.sleep’,args=[5]))
wf = Workflow([fw1, fw2, fw_timer], {fw1:fw_timer, fw_timer: fw2}, name=“test workflow”)
store workflow and launch it locally
launchpad.add_wf(wf)
~/working$ python3 test-wf.py
2019-01-23 10:53:15,208 INFO Performing db tune-up
2019-01-23 10:53:15,215 INFO LaunchPad was RESET.
2019-01-23 10:53:15,218 INFO Added a workflow. id_map: {-3: 1, -2: 2, -1: 3}
2019-01-23 10:53:15,287 INFO Created new dir /home/leid/working/launcher_2019-01-23-09-53-15-287161
2019-01-23 10:53:15,287 INFO Launching Rocket
2019-01-23 10:53:15,299 INFO RUNNING fw_id: 3 in directory: /home/leid/working/launcher_2019-01-23-09-53-15-287161
2019-01-23 10:53:15,308 INFO Task started: ScriptTask.
hello
2019-01-23 10:53:15,314 INFO Task completed: ScriptTask
I also tried others imports:
from fireworks.user_objects.firetasks.script_task import PyTask
or:
import fireworks.user_objects.firetasks.script_task
How should I do?
(And why is the documentation so unclear?)
You received this message because you are subscribed to the Google Groups “fireworkflows” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To post to this group, send email to [email protected].
Visit this group at https://groups.google.com/group/fireworkflows.
For more options, visit https://groups.google.com/d/optout.
Anubhav
