Dear LAMMPS users,
I am simulating a system with three atom types (type-1, type-2, type-3), and I want to apply:
- Lennard-Jones (LJ) interactions between type-2 and type-3
- WCA interactions (purely repulsive LJ) between all other pairs
I understand that WCA corresponds to a truncated and shifted LJ potential at the cutoff rc=21/6σ≈1.12246r_c = 2^{1/6} \sigma \approx 1.12246, which makes the potential zero at the cutoff.
Initially, I tried this:
pair_style lj/cut 2.5
pair_coeff 2 3 1.0 1.0 2.5
pair_modify shift yes
pair_coeff 1 3 1.0 1.0 1.12246
But I’m now unsure whether pair_modify shift yes
affects the WCA interaction (type 1–3) in a way that breaks its intended form.
My questions:
- Does
apply globally to alllj/cut
interactions, including those with a short cutoff (like 1.12246 for WCA)? - Will using it in combination with WCA effectively “double-shift” the interaction and distort the WCA potential?
- Is the recommended approach in this case to use
pair_style hybrid
to separately define LJ and WCA interactions? - Any potential issues or performance considerations with using
pair_style hybrid
for this case?
I’d really appreciate clarification or best practice suggestions for this mixed interaction setup.
Thank you,
Gokul Upadhyay
