Just as title says. I’m having a Validation Error relating to ‘has_props.’ I imported MPRester and the code involved in the error (below) is the only cell block I ran.
ValidationError Traceback (most recent call last)
Cell In[3], line 2
1 with mpr(api_key) as mp:
----> 2 docs = mp.materials.summary.search(material_ids=['mp-8688'])
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\mp_api\client\routes\materials\summary.py:283, in SummaryRester.search(self, band_gap, chemsys, crystal_system, density, deprecated, e_electronic, e_ionic, e_total, efermi, elastic_anisotropy, elements, energy_above_hull, equilibrium_reaction_energy, exclude_elements, formation_energy, formula, g_reuss, g_voigt, g_vrh, has_props, has_reconstructed, is_gap_direct, is_metal, is_stable, k_reuss, k_voigt, k_vrh, magnetic_ordering, material_ids, n, num_elements, num_sites, num_magnetic_sites, num_unique_magnetic_sites, piezoelectric_modulus, poisson_ratio, possible_species, shape_factor, spacegroup_number, spacegroup_symbol, surface_energy_anisotropy, theoretical, total_energy, total_magnetization, total_magnetization_normalized_formula_units, total_magnetization_normalized_vol, uncorrected_energy, volume, weighted_surface_energy, weighted_work_function, sort_fields, num_chunks, chunk_size, all_fields, fields)
273 query_params.update(
274 {"_sort_fields": ",".join([s.strip() for s in sort_fields])}
275 )
277 query_params = {
278 entry: query_params[entry]
279 for entry in query_params
280 if query_params[entry] is not None
281 }
--> 283 return super()._search(
284 num_chunks=num_chunks,
285 chunk_size=chunk_size,
286 all_fields=all_fields,
287 fields=fields,
288 **query_params,
289 )
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\mp_api\client\core\client.py:1072, in BaseRester._search(self, num_chunks, chunk_size, all_fields, fields, **kwargs)
1050 """A generic search method to retrieve documents matching specific parameters.
1051
1052 Arguments:
1067 A list of documents.
1068 """
1069 # This method should be customized for each end point to give more user friendly,
1070 # documented kwargs.
-> 1072 return self._get_all_documents(
1073 kwargs,
1074 all_fields=all_fields,
1075 fields=fields,
1076 chunk_size=chunk_size,
1077 num_chunks=num_chunks,
1078 )
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\mp_api\client\core\client.py:1119, in BaseRester._get_all_documents(self, query_params, all_fields, fields, chunk_size, num_chunks)
1105 list_entries = sorted(
1106 (
1107 (key, len(entry.split(",")))
1114 reverse=True,
1115 )
1117 chosen_param = list_entries[0][0] if len(list_entries) > 0 else None
-> 1119 results = self._query_resource(
1120 query_params,
1121 fields=fields,
1122 parallel_param=chosen_param,
1123 chunk_size=chunk_size,
1124 num_chunks=num_chunks,
1125 )
1127 return results["data"]
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\mp_api\client\core\client.py:411, in BaseRester._query_resource(self, criteria, fields, suburl, use_document_model, parallel_param, num_chunks, chunk_size, timeout)
408 if not url.endswith("/"):
409 url += "/"
--> 411 data = self._submit_requests(
412 url=url,
413 criteria=criteria,
414 use_document_model=use_document_model,
415 parallel_param=parallel_param,
416 num_chunks=num_chunks,
417 chunk_size=chunk_size,
418 timeout=timeout,
419 )
421 return data
423 except RequestException as ex:
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\mp_api\client\core\client.py:552, in BaseRester._submit_requests(self, url, criteria, use_document_model, parallel_param, num_chunks, chunk_size, timeout)
546 remaining_docs_avail = {}
548 initial_params_list = [
549 {"url": url, "verify": True, "params": copy(crit)} for crit in new_criteria
550 ]
--> 552 initial_data_tuples = self._multi_thread(
553 use_document_model, initial_params_list
554 )
556 for data, subtotal, crit_ind in initial_data_tuples:
557 subtotals.append(subtotal)
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\mp_api\client\core\client.py:766, in BaseRester._multi_thread(self, use_document_model, params_list, progress_bar, timeout)
763 finished, futures = wait(futures, return_when=FIRST_COMPLETED)
765 for future in finished:
--> 766 data, subtotal = future.result()
768 if progress_bar is not None:
769 progress_bar.update(len(data["data"]))
File ~\AppData\Local\Programs\Python\Python310\lib\concurrent\futures\_base.py:451, in Future.result(self, timeout)
449 raise CancelledError()
450 elif self._state == FINISHED:
--> 451 return self.__get_result()
453 self._condition.wait(timeout)
455 if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]:
File ~\AppData\Local\Programs\Python\Python310\lib\concurrent\futures\_base.py:403, in Future.__get_result(self)
401 if self._exception:
402 try:
--> 403 raise self._exception
404 finally:
405 # Break a reference cycle with the exception in self._exception
406 self = None
File ~\AppData\Local\Programs\Python\Python310\lib\concurrent\futures\thread.py:58, in _WorkItem.run(self)
55 return
57 try:
---> 58 result = self.fn(*self.args, **self.kwargs)
59 except BaseException as exc:
60 self.future.set_exception(exc)
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\mp_api\client\core\client.py:834, in BaseRester._submit_request_and_process(self, url, verify, params, use_document_model, timeout)
831 # other sub-urls may use different document models
832 # the client does not handle this in a particularly smart way currently
833 if self.document_model and use_document_model:
--> 834 raw_doc_list = [self.document_model.parse_obj(d) for d in data["data"]] # type: ignore
836 if len(raw_doc_list) > 0:
837 data_model, set_fields, _ = self._generate_returned_model(
838 raw_doc_list[0]
839 )
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\mp_api\client\core\client.py:834, in <listcomp>(.0)
838 raw_doc_list[0]
839 )
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\typing_extensions.py:2360, in deprecated.<locals>.decorator.<locals>.wrapper(*args, **kwargs)
2357 @functools.wraps(arg)
2358 def wrapper(*args, **kwargs):
2359 warnings.warn(msg, category=category, stacklevel=stacklevel + 1)
-> 2360 return arg(*args, **kwargs)
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\pydantic\main.py:1010, in BaseModel.parse_obj(cls, obj)
1004 @classmethod
1005 @typing_extensions.deprecated(
1006 'The `parse_obj` method is deprecated; use `model_validate` instead.', category=PydanticDeprecatedSince20
1007 )
1008 def parse_obj(cls: type[Model], obj: Any) -> Model: # noqa: D102
1009 warnings.warn('The `parse_obj` method is deprecated; use `model_validate` instead.', DeprecationWarning)
-> 1010 return cls.model_validate(obj)
File ~\AppData\Local\Programs\Python\Python310\lib\site-packages\pydantic\main.py:503, in BaseModel.model_validate(cls, obj, strict, from_attributes, context)
501 # `__tracebackhide__` tells pytest and some other tools to omit this function from tracebacks
502 __tracebackhide__ = True
--> 503 return cls.__pydantic_validator__.validate_python(
504 obj, strict=strict, from_attributes=from_attributes, context=context
505 )
ValidationError: 1 validation error for SummaryDoc
has_props
Input should be a valid dictionary [type=dict_type, input_value=['magnetism', 'electronic... 'xas', 'bandstructure'], input_type=list]
For further information visit https://errors.pydantic.dev/2.4/v/dict_type
