Hello everyone,
This is my first time using AMSET and I got this error by “amset wave”. The structure is bulk silicon.
FYI, I’m using vasp/5.3.3. The KPOINTS are 11111 and ENCUT is set to 300 (I also tried much lower ENCUT, lower KPOINTS and even tried AMSET on another machine).
I appreciate your help.
Mohammad
******* Getting wavefunction coefficients *******
Including bands 2—6
invalid value encountered in true_divide
******* Automatically choosing plane wave cutoff *******
File "/home/mohammad/.local/bin/amset", line 33, in <module>
sys.exit(load_entry_point('amset', 'console_scripts', 'amset')())
File "/home/mohammad/.local/lib/python3.7/site-packages/click/core.py", line 1128, in __call__
return self.main(*args, **kwargs)
File "/home/mohammad/.local/lib/python3.7/site-packages/click/core.py", line 1053, in main
rv = self.invoke(ctx)
File "/home/mohammad/.local/lib/python3.7/site-packages/click/core.py", line 1659, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/mohammad/.local/lib/python3.7/site-packages/click/core.py", line 1395, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/mohammad/.local/lib/python3.7/site-packages/click/core.py", line 754, in invoke
return __callback(*args, **kwargs)
File "/home/mohammad/2-Apps/15-AMSET/amset-main/amset/tools/wavefunction.py", line 104, in wave
ibands, planewave_cutoff, ikpoints, **kwargs
File "/home/mohammad/2-Apps/15-AMSET/amset-main/amset/tools/wavefunction.py", line 129, in _wavefunction_vasp
wf, iband=ibands, ikpoints=ikpoints, n_samples=2000, std_tol=0.02
File "/home/mohammad/2-Apps/15-AMSET/amset-main/amset/wavefunction/vasp.py", line 182, in get_converged_encut
wavefunction, encut=max_encut, pbar=False, iband=iband, ikpoints=ikpoints
File "/home/mohammad/2-Apps/15-AMSET/amset-main/amset/wavefunction/vasp.py", line 60, in get_wavefunction_coefficients
pbar=pbar,
File "/home/mohammad/2-Apps/15-AMSET/amset-main/amset/wavefunction/vasp.py", line 80, in _get_spin_wavefunction_coefficients
indices_map = np.full(np.max(valid_indices) + 1, -1, dtype=int)
File "<__array_function__ internals>", line 6, in amax
File "/home/mohammad/.local/lib/python3.7/site-packages/numpy/core/fromnumeric.py", line 2734, in amax
keepdims=keepdims, initial=initial, where=where)
File "/home/mohammad/.local/lib/python3.7/site-packages/numpy/core/fromnumeric.py", line 87, in _wrapreduction
return ufunc.reduce(obj, axis, dtype, out, **passkwargs)
ValueError: zero-size array to reduction operation maximum which has no identity
