varaible in loop
HI users,
I am using following lines,
HI users,
In continuation of above mail, I tried in this way
You define the fixes with the same fix I'd.
What you get is the expected behavior.
Axel.
Thanks Axel sir,
Now, changing the fix id, I am able to write into three files.
But still I am unable to write using variable and fix print ( first post ).
while using fix print how to substitute for variable.
Karteek Kumar
print 1 “${$a}”
I doubt this will work. Just use the print command like
the examples given, with one level of substitution.
