Dear all
I am a new user of lammps, so I apologize if I ask something trivial…
I have to model metal-oxide interfaces (Al-Al2O3, in particular).
To this purpose I need variable-charge potentials.
In literature I could find some potentials with different levels of refinements, such as:
1 - Streitz, Mintmire, PRB 50, 11996 (1994)
2 - X. W. Zhuo et al, PRB 69, 035402 (2004)
3 - A. Hasnaoui et al, Surface Science 579, 47 (2005) {Vashishta’s group}
4 - T. J. Campbell et al, PRB 71, 205413 (2005) {Vashishta’s group}
5 - Lazic & Thijsse, Comput. Mat. Sci. 53, 483 (2012)
For my purposes (and for stability reasons) I would need from potential 2 on.
I have found some posts on the Mailing list where the Al2O3 is discussed
(but couldn’t figure out if just an ionic was considered or in company with some metals…).
But when I looked in the files of the ReaxFF and COMB potentials I could not
find “Al” in the elements (I installed the version of last 7th September 2013).
Also I could find online some presentations by Taho Liang of 2013 (from the Phillpott group) discussing the availability of Al2O3 potential in COMB-3 for lammps.
Some other presentations, instead, where saying that its implementation is still under way.
My questions are, therefore:
Are these variable charge potentials implemented in lammps ?
What is the proper file where I can find them ?
What potential is implemented ?
If not, do we have an estimation of when it will be implemented or do you
have any advice on how implement it myself ? Can I find online some guidelines to understand the structure of the pair_potential files in order to implement that properly so to eventually make it available to the community also ?
Thank you very much in advance for your help.
Best regards
Daniele Scopece
