Hi all,
I was playing around with the oriented unit cells and noticed something interesting. I have a Structure that I’m running the get_primitive_structure() on, with some constraints. For some reason though, I get two different results depending on very small decimal differences in the constraints. You can reproduce this with the Structure in the json file I’m attaching with the following script;
fe310.json (4.9 KB)
from pymatgen.core.structure import Structure
import json
with open('fe310.json', 'r') as test:
fe310 = Structure.from_dict(json.load(test))
constraints1 = {'a': 2.831331845647057,
'b': 4.695232694497869,
'gamma': 107.5484006137923}
constraints2 = {'a': 2.831331845647057,
'b': 4.69523269449787,
prim1 = fe310.get_primitive_structure(constrain_latt=constraints1)
prim2 = fe310.get_primitive_structure(constrain_latt=constraints2)
The resulting primitive structures are quite different, even though the difference in the constraints is negligibly small. Does anyone have an idea why this might be happening?
