I recently installed vasp 6.3. I have been using the machine learning force field models and noticed that Vasprun failed to read in a relaxation calculation. I have uploaded the vasprun.xml file for reference.
Blockquote
In [1]: run = Vasprun(“vasprun.xml”)
IndexError                                Traceback (most recent call last)
Input In [1], in
----> 1 run = Vasprun(“vasprun.xml”)
File /data/miniconda/envs/pymatgen/lib/python3.9/site-packages/pymatgen/io/vasp/outputs.py:379, in Vasprun.init(self, filename, ionic_step_skip, ionic_step_offset, parse_dos, parse_eigen, parse_projected_eigen, parse_potcar_file, occu_tol, separate_spins, exception_on_bad_xml)
376         self.update_potcar_spec(parse_potcar_file)
377         self.update_charge_from_potcar(parse_potcar_file)
 → 379 if self.incar.get(“ALGO”, “”) not in [“CHI”, “BSE”] and (not self.converged):
380     msg = f"{filename} is an unconverged VASP run.\n"
381     msg += f"Electronic convergence reached: {self.converged_electronic}.\n"
File /data/miniconda/envs/pymatgen/lib/python3.9/site-packages/pymatgen/io/vasp/outputs.py:611, in Vasprun.converged(self)
604 @property
605 def converged(self):
606     “”"
607     Returns:
608         True if a relaxation run is converged both ionically and
609         electronically.
610     “”"
 → 611     return self.converged_electronic and self.converged_ionic
File /data/miniconda/envs/pymatgen/lib/python3.9/site-packages/pymatgen/io/vasp/outputs.py:585, in Vasprun.converged_electronic(self)
578 @property
579 def converged_electronic(self):
580     “”"
581     Returns:
582         True if electronic step convergence has been reached in the final
583         ionic step
584     “”"
 → 585     final_esteps = self.ionic_steps[-1][“electronic_steps”]
586     if “LEPSILON” in self.incar and self.incar[“LEPSILON”]:
587         i = 1
IndexError: list index out of range
Blockquote
vasprun.xml.gz (2.1 MB)
