Dear lammps users,
I hope I can get some help, this is my first time using lammps. I am trying to get the velocity profile for couette flow. I get the velocities using the code below, then calculate averages and plot them, I don’t get the linear velocity profile. Velocities are wrong. I tried several attempts, hence some lines are commented out.
Also, when I run the simulation, I am getting 10000 atoms in group boundary and only 1200 atoms in group flow, I think this might be the problem but not sure. How can I have more atoms in group flow?
If anyone can tell me what am I doing wrong and how can I get the linear velocity profile, I would really appreciate.
Thank you all
Haz
2-d LJ flow simulation
dimension 2
boundary p s p
atom_style atomic
#units real
neighbor 0.3 bin
neigh_modify delay 5
create geometry
lattice hex 0.7
region box block 0 80 0 70 -0.25 0.25
create_box 3 box
create_atoms 1 box
mass 1 1.0
mass 2 1.0
mass 3 1.0
LJ potentials
pair_style lj/cut 1.12246
pair_coeff * * 1.0 1.0 1.12246
define groups
region 1 block INF INF INF 1.25 INF INF
group lower region 1
region 2 block INF INF 8.75 INF INF INF
group upper region 2
group boundary union lower upper
group flow subtract all boundary
set group lower type 2
set group upper type 3
initial velocities
#compute mobile flow vacf
compute mobile flow temp
#compute mobile flow temp/profile 1 0 0 xy 20
#velocity flow create 50.0 482748 sum yes dist gaussian
#velocity flow scale 50.0 sum yes dist gaussian
velocity flow ramp vx 0 3 y 0 70 dist gaussian
#velocity flow ramp vx 0 3 y 0 70 dist gaussian
#fix 1 all nve
fix 1 all nvt temp 1.0 1.0 1.0
#fix 2 flow temp/rescale 1 50.0 50.0 0.02 1.0
#fix_modify 2 temp mobile
Couette flow
velocity lower set 0.0 0.0 0.0
velocity upper set 3.0 0.0 0.0
fix 3 boundary setforce 0.0 0.0 0.0
fix 4 all enforce2d
Run
timestep 0.003
thermo 500
#thermo_modify temp mobile
dump 1 all custom 500 velocities1.txt type vx vy vz
#dump 1 all image 100 image.*.jpg type type &
zoom 1.6 adiam 1.2
#dump_modify 1 pad 5
run 10000
