Verification of Lammps Installation
Dear Sirs
I tried to install the Lammps and found the following message as follows
size …/lmp_openmpi
text data bss dec hex filename
6450280 11648 16368 6478296 62d9d8 …/lmp_openmpi
make[1]: Leaving directory `/usr/local/src/lammps-1Feb14/src/Obj_openmpi’
natesh@…5176…:/usr/local/src/lammps-1Feb14/src$ mkdir -p ~/bin
natesh@…5176…:/usr/local/src/lammps-1Feb14/src$ cp lmp_openmpi ~/bin
So I want to check the installation correct or not. And also requesting any other correction and further advanced options like that.
Thanking you,
O.A.Natesh.
Dear Sirs
message as follows
size ../lmp_openmpi
6450280 11648 16368 6478296 62d9d8 ../lmp_openmpi
make[1]: Leaving directory `/usr/local/src/lammps-1Feb14/src/Obj_openmpi'
[email protected]...:/usr/local/src/lammps-1Feb14/src$ mkdir -p ~/bin
[email protected]...:/usr/local/src/lammps-1Feb14/src$ cp lmp_openmpi
~/bin
the version you installed is already *way* outdated.
