fix corrO liqO ave/correlate $s $p $d v_pxy v_pxz v_pyz type auto file acorr_O.dat ave running
fix corrC liqC ave/correlate $s $p $d v_pxy v_pxz v_pyz type auto file acorr_C.dat ave running
but the content of the files acorr_O.dat and acorr_C.dat are the same. What i want is to calculate the autocorrelation for oxygen and carbone the frames of one run, and they sould obviosly differ, can one do that? What am i doing wrong here?
The pxy, pxz, and pyz thermo properties are global properties and equal style variables are global, similarly fix ave/correlate operates on global data, hence the two fix commands must produce the same output. Mind you, the documentation for fix ave/correlate explicitly states that it ignores the group ID.
Pressure in general is a global property, so computing pressure for a subset of atoms is not a well defined property. In principal, you can compute pressures of sub-volumes by using compute stress/atom, compute reduce, and then divide by the volume. But the volume of individual atoms is not well defined, so you would have to come up with a meaningful approximation, which is not easy.
Thank your for the meaningful response!
If I undurstand you correctly, in standart approach, the calculation of the autocorrelation (consequently a viscosity) for a single group/groups of atom is impracticable. So, in my example the computed results are for the whole system? If i need to separte a specific group/groups of atom I should think about a proper pressure approximation for that group/groups?
