Dear Lammps-Users,
I have been working towards calculation of viscosity of spherical colloidal particles using lammps via fix deform/box deformation method. I am having trouble controlling the temperature of my simulation system.
When I start the simulation and equilibrate the system via fix nve/langevin combination, the system fluctuates near desired temperature…
Step Temp PotEng KinEng TotEng Volume Press Density Lx Ly Lz
0 293.15 -0.12767348 10485.02 10484.892 3000000 159.759 1.4739087 200 150 100
100000 295.66051 13.806628 10574.812 10588.619 3000000 162.61987 1.4739087 200 150 100
…but when I start the dynamics and continue with fix nvt/sllod, fix deform and thermo_modify temp tilt …
fix 1 all nvt/sllod temp $T T 10.0**
**fix 2 all deform 1 xy erate {xyrate} remap v
compute tilt all temp/deform
…The temperature go haywire and produce very weird temperature scales…as you can see below…
Step Temp c_usual PotEng TotEng Press Volume Density Pxy
0 4.2949786e+09 293.15 13.806628 1.5361738e+11 2.3407334e+09 3000000 1.4739087 -14333.337
1000 0.015867274 4.2949592e+09 4663.6396 4664.2071 428.3836 3000000 1.4739087 -296.23367
2000 0.019312198 4.2961639e+09 4003.8359 4004.5266 367.81751 3000000 1.4739087 -264.03971
3000 0.033997626 4.296414e+09 7143.45 7144.6659 655.79255 3000000 1.4739087 -442.22302
4000 0.024984739 4.2964145e+09 4205.5584 4206.452 386.34433 3000000 1.4739087 -317.34612
5000 0.0079016446 4.2959051e+09 3260.3266 3260.6092 299.873 3000000 1.4739087 -144.8736
6000 0.0095063252 4.2959047e+09 3222.4306 3222.7706 296.37825 3000000 1.4739087 -165.70544
7000 0.015150939 4.2959054e+09 4979.2388 4979.7807 457.39181 3000000 1.4739087 -263.68253
8000 0.0062240888 4.2956523e+09 3564.6123 3564.8349 327.92871 3000000 1.4739087 -99.314651
9000 0.0025053293 4.2956511e+09 2076.462 2076.5516 191.36842 3000000 1.4739087 -41.894239
10000 0.0031442948 4.295902e+09 2069.961 2070.0735 190.68147 3000000 1.4739087 -57.838724
…and continue the same in the data collection run.
Attached is the input script I am using for the run. Could anyone please give me a hint what am I doing wrong here??
on another note, It may be very lame question(apologies in advance) but even after using nvt/sllod , Am I still doing implicit solvent simulation?? (I want to run implicit solvent only).
Every bit of help and suggestion is greatly appreciated.
Thanking you
Best
Raghvendra
temp_defom.in (5.09 KB)
