ITEM: ATOMS x y z vx vy vz
8.24237 1.64188 3.25677 -9.29001 4.79773 32.1441
8.52572 0.979111 1.84303 -22.6713 -18.1494 -7.48348
I want to visualize the velocity vector with arrows originating from each atom. From online searches, it appears that it is possible to produce such renders; however, I am not sure how exactly. I am using Ovito Basic Version 3.7.8. I would be grateful if someone could kindly provide some directions. Thanks for your attention.
When you load a file containing particle velocities into OVITO, a corresponding visual element is created automatically. However, it is deactivated by default to keep the viewport uncluttered. You can enable the arrow representation for velocities by checking the highlighted box.
It looks like OVITO did not correctly match the particle properties. Ideally, this should happen automatically. Could you please upload your file here so I can investigate further?
As a workaround, you can manually set the column mapping using the dialog shown. More information is available in the manual. The dialog in the second screenshot needs to be configured based on your specific dump file.
