I am trying to install voronoi package following the instructions existing in README file from Voro++ - A 3D Voronoi cell software library. However, I encountered the following compilation error when i run % make in the folder. (cygwin)
$ make
make -C src
make[1]: Entering directory ‘/cygdrive/c/Users/user/Downloads/voro+±0.4.6/src’
g++ -Wall -ansi -pedantic -O3 -c cell.cc
make[1]: g++: No such file or directory
make[1]: *** [Makefile:31: cell.o] Error 127
make[1]: Leaving directory ‘/cygdrive/c/Users/user/Downloads/voro+±0.4.6/src’
make: *** [Makefile:14: all] Error 2
Hope anyone could provide some guidance. Thanks in advance.
The error message means, that the GNU C++ compiler cannot be found. This either means that you did not install it or that your PATH environment variable is not correctly set up for your cygwin installation.
This is the wrong place to ask. This is a forum for a different software.
Anyway, the error message is pretty self-explanatory. You either have not installed the g++ compiler or it is not configured correctly. Without a working compiler you cannot compile software.
I only posted it here only because the compilation errors are quite similar but I know better now. Thanks for your response. I have been able to resolve the problem. Cheers!
