Hello, I am using LAMMPS-7Aug19. I am attempting to simulate a piece of string by bonding particles together in a line. I want this string to be finitely extensible under any reasonable tensile force, so the FENE bond potential is appealing, but I am having trouble getting it to work. In the following code, I initialize the particles such that the nearest neighbor distance is 0.25m. I set the FENE cutoff distance R0 to be 0.255m, and I choose sigma to be such that the minimum of the FENE potential, as detailed in the LAMMPS documentation here (https://lammps.sandia.gov/doc/bond_fene.html), is very close to 0.25m. However, LAMMPS throws the error “WARNING: FENE bond too long” on the 0th timestep, even though according to the code and the dump file which I output, the bonded atoms are 0.25m from each-other, which is below the FENE cutoff distance, and continues to throw the error if I run the simulation for longer. Here is the code:
atom_style hybrid sphere bond
units si
processors * * 1
comm_modify vel yes
