Hi Lammps Users
I am trying to run a polymer chain simulation. I defined the bond and angle as per the "table" style requirement.
bond_style table spline 10000
bond_coeff 1 Coeff_Bond_Table bond_type_1
bond_coeff 2 Coeff_Bond_Table bond_type_2
bond_coeff 3 Coeff_Bond_Table bond_type_3
angle_style table spline 1500
angle_coeff 1 Coeff_Angle_Table angle_type_1
angle_coeff 2 Coeff_Angle_Table angle_type_2
angle_coeff 3 Coeff_Angle_Table angle_type_3
angle_coeff 4 Coeff_Angle_Table angle_type_4
angle_coeff 5 Coeff_Angle_Table angle_type_5
angle_coeff 6 Coeff_Angle_Table angle_type_6
I initially had only the distance/angle and energy values for all bond and angle types.
I used the following lines in python to create force and derivative values:
cs = CubicSpline(bondlengthList, energyList)
forceList = cs(bondlengthList, 1)
cs = CubicSpline(angleList, energyList)
energyDerivativeList = cs(angleList, 1)
Is this a correct method? After using these force values in the bond and angle table, I get the following warning messages and a segmentation fault. Could someone help me to understand and rectify it.
WARNING: 1490 of 1501 force values in table are inconsistent with -dE/dr. Should only be flagged at inflection points
WARNING: 1492 of 1501 force values in table are inconsistent with -dE/dr. Should only be flagged at inflection points
