Dear LAMMPS-users,
I am trying to simulate the kerogen molecule with REAX/C package. But I got the following warning:
WARNING: H matrix size has been exceeded: m_fill=6424 H.m=6237
(…/fix_qeq_reax.cpp:623)
I build a low density file and try to compress the system with NPT ensemble (400 K, 30 MPa). The input file is as follows:
ReaxFF potential for kerogen system
units real
atom_style full
read_data data.kerogen_II_D_configuration_1
ReaxFF
pair_style reax/c control.reax_c.rdx
pair_coeff * * ffield.reax C H O N S
minimize 1.0e-4 1.0e-6 100 10000
compute reax all pair reax/c
variable eb equal c_reax[1]
variable ea equal c_reax[2]
variable elp equal c_reax[3]
variable emol equal c_reax[4]
variable ev equal c_reax[5]
variable epen equal c_reax[6]
variable ecoa equal c_reax[7]
variable ehb equal c_reax[8]
variable et equal c_reax[9]
variable eco equal c_reax[10]
variable ew equal c_reax[11]
variable ep equal c_reax[12]
variable efi equal c_reax[13]
variable eqeq equal c_reax[14]
velocity all create 400.0 4928459 rot yes dist gaussian
neighbor 2.5 bin
neigh_modify every 10 delay 20 check yes
thermo_style custom step temp epair etotal vol press &
v_eb v_ea v_elp v_emol v_epen v_ecoa v_ehb &
v_et v_eco v_ew v_ep v_efi v_eqeq
thermo 10000
timestep 0.1
fix 1 all npt temp 400.0 400.0 10.0 iso 300.0 300.0 100.0
fix 2 all qeq/reax 10 0.0 10.0 1.0e-6 reax/c
fix 4 all reax/c/bonds 400000 bonds_400_p_30.reaxc
dump 1 all xyz 2000 kerogen_reax_npt_400_p_30.xyz
dump 2 all image 200000 kerogen_reax_npt_400_p_30.*.png type type size 1280 720
dump 3 all custom 200000 kerogen_reax_npt_400_p_30.txt id type mass x y z q
info all out simulation_log.txt
run 4000000 # 400 ps
write_restart kerogen_reax_npt_p_30_t_400.restart
write_data kerogen_reax_npt_p_30_t_400.data
reset_timestep 0
unfix 1
fix 5 all nve
Please find the data file in the attached. Any help would be appreciated. Thanks in advance.
Bests,
Shuai
data.kerogen_II_D_configuration_1 (77.3 KB)
