This is my new command,
fix fxnvt notCO nvt temp 340.0 340.0 0.1
fix rigid CO rigid/nvt group 1 CO temp 340 340 1
I have a question, as you see above, I want to perform an NVT ensemble for my simulation box.
Will it be possible to do it by prior two commands?
Because, I remembered that you said that it is not an NVT ensemble when you use rigid/nvt. Am I right?
340.0 0.1
temp 340 340 1
my simulation box.
that is easy to test for and to find out. this is the lammps-*users*
mailing list and not the lammps-*input-file-approval* list. it is
*your* job to verify whether something works or not.
you are quoting me out of context and thus you are likely quoting me
wrong. but i can't know.
Okayyyyyyyyyy, it is my jobbb. you are right.
You left out this:
group notCO subtract all CO
("notCO" is the name of a group which you create with this command.) See:
http://lammps.sandia.gov/doc/group.html
Andrew
340.0 0.1
temp 340 340 1
Cheers
Andrew
Dear Andrew,
Thank you for correcting my post. I forgot to add the group command,
