I use shell scripts to symbolically link restart files to sub directories after a run completes. Recently, due to an embarrassingly simple typo, the symbolic link did not point to a restart file (it actually pointed to a directory). When LAMMPS was executed the following error occurred:
WARNING: Restart file version does not match LAMMPS version
restart file = , LAMMPS = 17 Feb 2012
Which was odd, because I’ve used the 17Feb12 version of LAMMPS for a few months now. I’m posting this error for two reasons:
1.) Googling this error doesn’t bring up very many results. Hopefully this post will remind others to double-check that the restart file is actually a restart file.
2.) To suggest the addition of a separate warning condition, something along the lines of “WARNING: Specified restart file is not a LAMMPS restart file.” Not sure how difficult this would be, but as you can see from the posted error, the version information is completely absent from the left side of the comma (restart file = ,). Perhaps if version information is completely absent from the specified file a separate warning could be generated.
David
