Hi all,
I want to use ReaxFF force field to simulate the insertion of Li ions in Si anode. However, there are always some warnings which are:
Warning: inconsistent vdWaals-parameters Force field parameters for element X indicate shielding without inner wall, but earlier atoms indicate different vdWaals-method.
This may cause division-by-zero errors. Keeping vdWaals-setting for earlier atoms.
Is anyone can help me to point out the problems in my script?
The script file is:
#------------Initialization----------------#
clear
units real
boundary s p p
newton on
atom_style charge
neighbor 3.0 bin
neigh_modify every 1 delay 1
#-----------------Create Atoms-----------------#
read_data data.a-Si_1000
#----------------Variable Definition------------#
variable N equal step
variable V equal vol
variable T equal temp
variable PE equal pe
variable ETOTAL equal etotal
variable P equal press
variable Lx equal lx
variable Ly equal ly
variable Lz equal lz
variable Pxx equal pxx
variable Pyy equal pyy
variable Pzz equal pzz
#--------------Output Settings-----------------#
thermo_style custom step etotal pe vol temp press
thermo 1000
timestep 0.001
#----------------velocity setting---------------#
velocity all create 300 5812775 dist gaussian units box
#--------------Initial dimensions of simulation box--------#
variable tmpx equal "lx"
variable tmpy equal "ly"
variable tmpz equal "lz"
variable Lx equal {tmpx}**
**variable Ly equal {tmpy}
variable Lz equal {tmpz}**
**print "Initial Lengths, Lx = {Lx}, Ly = {Ly}, Lz = {Lz}"
dump mydump all custom 50000 a-Si_insertion.lammpstrj id type x y z
fix output all print 1000 “{N} {V} {T} {PE} {ETOTAL} {P} {Lx} {Ly} {Lz} {Pxx} {Pyy} {Pzz}” file a_Si_3.75.txt
#--------------Insert Lithium atoms + Relaxation-------------#
label forloop
variable i loop 50 #insert atoms 50 times
group alloy type 1 2
create_atoms 2 random 75 721452 NULL
group Li subtract all alloy
set group Li charge 1.0
pair_style reax/c NULL
pair_coeff * * ffield.reax Si Li
fix Qeq all qeq/reax 1 0.0 10.0 1e-6 reax/c
fix 1 all nve/limit 0.1
run 30000
unfix 1
fix 2 all nvt temp 300 300 0.05
run 50000
unfix 2
write_restart restart.Li_insert.Loop$i
next i
jump Li_insertion.in forloop
#--------------Output datafiles------------#
write_data data.a-Si_insertion_3.75
write_restart restart.a-Si_insertion_3.75
Kind regards,
MC
