Hi users,
I met a problem that the water molecules are not confined in my periodic box. At the beginning, I have about 9900 water molecules (SPCE water), after my simulation, ~ 1.5 ns, only about few hundred left. Other molecules are dispersed outside of the box. But the system never reported any error about losing atoms. Besides, I have 36 big particles in the box as well, but they are moving around but staying in the box. I am using a very small timestep 0.1 fs, and I did try smaller, the same result. Later, I also tried with a coarse-grain model water developed by Dr.Valeria Molinero, still same thing happens.
Is this problem possibly caused by my charged atoms? I saw a warning during the simulation said my system charge is not neutral.
This is my input script. Many thanks for your help.
----------------- Init Section -----------------
#include “system.in.init_m”
units real
atom_style hybrid full sphere
pair_style hybrid yukawa/colloid 2.0 2.5 lj/charmm/coul/long 9.0 10.0 10.0
bond_style hybrid harmonic fene
angle_style harmonic
kspace_style ewald 0.0001
pair_modify mix arithmetic
special_bonds fene
----------------- Atom Definition Section -----------------
read_data “systemw.data”
----------------- Settings Section -----------------
#include “system.in.settings_m”
bond_coeff 1 fene 1 2.5 1.5 1.0
bond_coeff 2 harmonic 200.0 1.0
angle_coeff 1 200.0 109.47
pair_coeff * * yukawa/colloid 100.0 2.3
pair_coeff 2 2 yukawa/colloid 100.0 2.3
pair_coeff 3 3 lj/charmm/coul/long 0.1553 3.166
pair_coeff 4 4 lj/charmm/coul/long 0.0 2.058
Load the atom coordinates:
include “systemw.in.coords”
----------------- Run Section -----------------
The lines above define the system you want to simulate.
What you do next is up to you.
Typically a user would minimize and equilibrate
the system using commands similar to the following:
---- examples ----
group particle molecule <> 1 36
group water type 3 4
fix 1 particle rigid molecule
communicate multi vel yes
fix fSHAKE water shake 0.0001 10 50 b 2 a 1
– minimize –
timestep 0.005
thermo_style custom step temp vol press etotal
thermo 100
dump min all custom 100 min.lammpstrj id mol type x y z ix iy iz
fix fxlan all langevin 298 298 100.0 48279
fix fxnve all nve
fix tmp all temp/rescale 100 280 330 1.0 1.0
run 10000
unfix fSHAKE
minimize 1.0e-4 1.0e-6 100 1000
(Note: Some fixes, for example “shake”, interfere with the minimize command,
You can use the “unfix” command to disable them before minimization.)
– declare time step for normal MD –
timestep 0.1
– run at constant pressure (Nose-Hoover)–
fix fxnpt all npt temp 300.0 300.0 100.0 iso 1.0 1.0 1000.0 drag 1.0
– ALTERNATELY, run at constant volume (Nose-Hoover) –
fix fxnvt all nvt temp 300.0 300.0 500.0 tchain 1
– ALTERNATELY, run at constant volume using Langevin dynamics. –
– (This is good for sparse CG polymers in implicit solvent.) –
#velocity all create 300 245634
#fix fxlan all langevin 300.0 300.0 100 48279
#fix fxnve all nve
#fix fxnvt all nvt temp 300 300 500
thermo 5000
dump 1 all custom 5000 test.lammpstrj id mol type x y z ix iy iz
run 5000000
#run 5000000
#run 5000000
