Hi devs and community of LAMMPS
First of all, thank you for the powerful and versatile code! Awesome Job (with the capitol J)
Recently I was trying to dump a .xml trajectory of my simulation using the dump molfile command, and I encountered some problem. I am using LAMMPS 14May2016.
My command is
dump t_xml all molfile 500 traj.xml hoomd /home/federico/programs/sources/library/hoomd-molfile-plugin/LINUXAMD64
and when it runs produced the annoying error
ERROR on proc 0: No suitable molfile plugin found (../dump_molfile.cpp:109)
First of all, I tried others plugin, to understand if something was missing in the path (you never know). However, pdb and dcd were working fine, and I was able to write and read these files.
I tried with vaspxml, but I got the same error.
I tried to hack my way in the code, and I find out that the hoomd plugin, and only that one, cannot be opened by dlopen in molfile_interface.cpp.
by inserting the command
if(!dlopen(fname, RTLD_NOW))
std::cout << fname << ' ' << dlerror() << std::endl;
I got
/home/federico/programs/sources/library/hoomd-molfile-plugin/LINUXAMD64/hoomdplugin.so libexpat.so.0: cannot open shared object file: No such file or directory
Which is weird, since all the other plugin can be opened. For no apparent reason (to me) if I try to use vaspxml, the plug-in is open with dlopen, but the code answer again
I tried to reinstall the MOLFILE plug-ins but with no luck. I am using the header of VMD 1.9.2 and not those in the original package of LAMMPS.
I also have a large number of trajs to convert in .xml (~200 files), and I was planning to use LAMMPS, by reading and writing with molfile.
So the question is: Am I doing something weird? Is the molfile plug-ins that I have? Or is it something weird with LAMMPS?
Thank you very much for the code and the support!
F.
