I was running a eam/alloy simulation fine with the GPU package yesterday.
After I ran it, I ran an update for Fedora 20, which included an update to
the kernel and gpu driver. Since then, when I go to run my simulation I
receive this message,
LAMMPS (30 Jan 2014)
Reading data file ...
orthogonal box = (-0.426382 -0.426382 -0.426382) to (49.2064 49.2064
49.2064)
reading atoms ...
6750 atoms
reading velocities ...
6750 velocities
- Using GPGPU acceleration for eam:
- with 1 proc(s) per device.
GPU 0: GeForce GTX 660 Ti, 1344 cores, 2.7/3 GB, 1.1 GHZ (Double Precision)
Initializing GPU and compiling on process 0...Done.
Initializing GPU 0 on core 0...Done.
Setting up run ...
ERROR on proc 0: Insufficient memory on accelerator
(../pair_eam_gpu.cpp:133)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
Cuda driver error 4 in call at file 'geryon/nvd_timer.h' in line 98.
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 0
Cuda driver error 4 in call at file 'geryon/nvd_device.h' in line 124.
I noticed it says it is using 2.7-2.8 GB out of 3GB available on the GPU but
when I check this through the system it is only using a few hundred MB at
any given time. I have NOT changed anything in my input script from when it
was working fine til now. Would the updated driver cause an issue like this
and should I try to rollback to a previous version? I did do a clean build
difficult to say. you should carefully check your system log. i assume
you did do a reboot. depending on how you installed the nvidia drivers
(which ones do you use exactly?) your configuration might have gotten
out of whack. i have this on my F20 box:
[[email protected]... src]$ rpm -qa | grep -i nvid
xorg-x11-drv-nvidia-331.38-1.fc20.x86_64
akmod-nvidia-331.38-5.fc20.x86_64
xorg-x11-drv-nvidia-devel-331.38-1.fc20.x86_64
xorg-x11-drv-nvidia-libs-331.38-1.fc20.x86_64
kmod-nvidia-3.12.6-300.fc20.x86_64-331.38-5.fc20.x86_64
of the GPU library as well as a clean build of LAMMPS after the update and I
received the message the first time.
rebuild should not make a difference. since you didn't change the
toolkit or compiler.
i have not tested the GPU package in a while, so this is a good reason
to make a check.
more later,
