I am wondering what are (in your experience) best practices to debug where a ReaxFF MD segmentation fault might come from?
What check list would you follow to find the exact setup/parameter or any other factor that is causing the segmentation fault?
Here is a code that generates a segmentation fault error at around a few 1000 steps running on Ubuntu 22, 128 cores, 100 G mem, takes a few short minutes.
That requires far too many resources for meaningful debugging.
I do my best debugging, when I can reach the crash with 8 cores within less than a minute.
I just happened to run across a few server with 64 cores and the input ran to completion:
LAMMPS (12 Jun 2025 - Development - patch_12Jun2025-533-gcdded2d51c)
KOKKOS mode with Kokkos version 4.6.1 is enabled
package kokkos
# Created by charmm2lammps v1.8.1 on Fri Jan 28 00:27:31 EST 2022
Loop time of 552.961 on 64 procs for 100000 steps with 2260 atoms
Performance: 0.781 ns/day, 30.720 hours/ns, 180.845 timesteps/s, 408.709 katom-step/s
91.0% CPU use with 64 MPI tasks x 1 OpenMP threads
This is the current LAMMPS development version using the KOKKOS implementation of ReaxFF on the CPU and without threads.
mpirun -np 64 env OMP_NUM_THREADS=1 OMP_PROC_BIND=false ./lmp -in in_1slab.input -k on t 1 -sf kk
The KOKKOS package version has a more robust memory management (required by the port to KOKKOS) and should be a little bit faster, too, since it has been optimized more.
