I wanted to know what is the units of the cut-off distance and the pair separation distance in the radial distribution function obtained from coordination analysis.
Thank you
Thank you
OVITO uses Angstroms as the unit of length, so you’ll find references to Angstroms throughout the manual. However, the modifiers operate solely on values, not units. This means that if you load a file where distances are stored in meters, the radial distribution function will also be returned in meters.
