Hello, I am using the latest miniconda to install ovito python, the conda version is 24.1.2, the python version is 12.2.
I came across the installation command ‘conda install --strict-channel-priority -c https://conda.ovito.org -c conda-forge ovito=3.10.4’ on the ovito official website, but error happened, "LibMambaUnsatisfiableError: Encountered problems while solving:
- package ovito-3.10.4-py310h751f6f3_0 requires python >=3.10,<3.11.0a0, but none of the providers can be installed
Could not solve for environment specs
The following packages are incompatible
├─ ovito 3.10.4** is installable with the potential options
│ ├─ ovito 3.10.4 would require
│ │ └─ python >=3.10,<3.11.0a0 , which can be installed;
│ │ └─ python >=3.11,<3.12.0a0 , which can be installed;
│ │ └─ python >=3.8,<3.9.0a0 , which can be installed;
│ │ └─ python >=3.9,<3.10.0a0 , which can be installed;
│ └─ ovito 3.10.4 conflicts with any installable versions previously reported;
└─ pin-1 is not installable because it requires
└─ python 3.12.* , which conflicts with any installable versions previously reported.
Pins seem to be involved in the conflict. Currently pinned specs:
- python 3.12.* (labeled as ‘pin-1’)"
Because I can use pip install ovito python even though my python version is 12.2, I feel confused. I want to how I can install?
Thanks a lot.
Fan
