Where to find external functions from cuda library for atom decomposition?
Hi! I am modifying our research group’s inhouse potential file to be compatible with GPU package. I am learning by looking at pair_lj_cut_gpu.cpp file. I want to find out where these functions are defined in the following code:
// External functions from cuda library for atom decomposition
int ljl_gpu_init(const int ntypes, double **cutsq, double **host_lj1, double **host_lj2,
                 double **host_lj3, double **host_lj4, double **offset, double *special_lj,
                 const int nlocal, const int nall, const int max_nbors, const int maxspecial,
                 const double cell_size, int &gpu_mode, FILE *screen);
void ljl_gpu_reinit(const int ntypes, double **cutsq, double **host_lj1, double **host_lj2,
                    double **host_lj3, double **host_lj4, double **offset);
void ljl_gpu_clear();
int **ljl_gpu_compute_n(const int ago, const int inum, const int nall, double **host_x,
                        int *host_type, double *sublo, double *subhi, tagint *tag, int **nspecial,
                        tagint **special, const bool eflag, const bool vflag, const bool eatom,
                        const bool vatom, int &host_start, int **ilist, int **jnum,
                        const double cpu_time, bool &success);
void ljl_gpu_compute(const int ago, const int inum, const int nall, double **host_x, int *host_type,
                     int *ilist, int *numj, int **firstneigh, const bool eflag, const bool vflag,
                     const bool eatom, const bool vatom, int &host_start, const double cpu_time,
                     bool &success);
double ljl_gpu_bytes();
In what file are these functions defined? The comment suggested these are from the Cuda library for atom decomposition. I have went on to the official Cuda library website. There isn’t a library that correspond to atom decomposition.
Thanks!
You seem to be confusing what we refer to as “the GPU library” with “a CUDA library”. The LAMMPS GPU library is located in the lib/gpu folder.
Thank you very much!
