Recently I met a problem when I tried to reset some environment settings during a single run. The input file is presented below.
run 10000 #for test
write_data Si.data
write_restart Restart.Si
variable myTemp equal temp
if “{myTemp} > 400" then &
"variable bottem_top equal Bound(top,zmin)" &
"fix wall middle all/reflect zhi v_bottem_top" &
"variable ts equal timestep" &
"print 'timestep {ts}’” &
“run 300000” &
“write_data Si_stretch.data” &
“write_restart Si_stretch.restart” &
“quit”
run 350000
write_restart Restart.Si_stretch
I want to execute the IF command for only once. The original idea came up to me is to set the command as ‘if "${myTemp} > 400 && once’" and change the numeric value of the once when the if command executed. But iI cannot find a suitable style variable to do this. So I am wondering if there is a suitable variable style to do this job?
Then i set the input file just as above, however, a new error came up with “Compute used in variable thermo keyword between runs is not current”, it seems that it is not allowed to reference to a thermo keyword in a new run while the old run has not yet finished. Is there any way to refer to it?
Regards,
Xiaoneng
