Which version of Numpy is preferred for Matminer install?
Matminer is having trouble with the version of numpy (1.15.0) I have installed. The following messages are presented when import numpy:
import matminer
/usr/local/lib/python2.7/dist-packages/pandas/_libs/init.py:4: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from .tslib import iNaT, NaT, Timestamp, Timedelta, OutOfBoundsDatetime
/usr/local/lib/python2.7/dist-packages/pandas/init.py:26: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import (hashtable as _hashtable,
/usr/local/lib/python2.7/dist-packages/pandas/core/dtypes/common.py:6: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import algos, lib
/usr/local/lib/python2.7/dist-packages/pandas/core/util/hashing.py:7: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import hashing, tslib
/usr/local/lib/python2.7/dist-packages/pandas/core/indexes/base.py:7: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import (lib, index as libindex, tslib as libts,
/usr/local/lib/python2.7/dist-packages/pandas/tseries/offsets.py:21: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
import pandas._libs.tslibs.offsets as liboffsets
/usr/local/lib/python2.7/dist-packages/pandas/core/ops.py:16: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import algos as libalgos, ops as libops
/usr/local/lib/python2.7/dist-packages/pandas/core/indexes/interval.py:32: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs.interval import (
/usr/local/lib/python2.7/dist-packages/pandas/core/internals.py:14: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import internals as libinternals
/usr/local/lib/python2.7/dist-packages/pandas/core/sparse/array.py:33: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
import pandas._libs.sparse as splib
/usr/local/lib/python2.7/dist-packages/pandas/core/window.py:36: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
import pandas._libs.window as _window
/usr/local/lib/python2.7/dist-packages/pandas/core/groupby/groupby.py:68: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import (lib, reduction,
/usr/local/lib/python2.7/dist-packages/pandas/core/reshape/reshape.py:30: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import algos as _algos, reshape as _reshape
/usr/local/lib/python2.7/dist-packages/pandas/io/parsers.py:45: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
import pandas._libs.parsers as parsers
/usr/local/lib/python2.7/dist-packages/pandas/io/pytables.py:50: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
from pandas._libs import algos, lib, writers as libwriters
/usr/local/lib/python2.7/dist-packages/scipy/sparse/lil.py:19: RuntimeWarning:
/usr/local/lib/python2.7/dist-packages/scipy/sparse/csgraph/init.py:165: RuntimeWarning:
Ideas? or the preferred version?
-Dennis
AFAIK numpy 1.15.0 should work. The error seems to be due to the installation of the pandas library which is separate from matminer and a pretty well-supported library. i.e. you will probably get the same error from typing “import pandas”
I would check / update your pandas installation
Most of us use anaconda to install pandas / etc. which is typically a pretty stable way to do it. Although perhaps the issue is also there with conda: numpy.dtype size changed, may indicate binary incompatibility · Issue #6678 · ContinuumIO/anaconda-issues · GitHub
There seem to be multiple discussions of this error on the web (e.g. python - RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility - Stack Overflow) but none really seem related to matminer itself
Anubhav
import matminer
-Dennis
The fix via the stackoverflow worked. The problem was with scipy install. Now I’m having issues with Pymatgen.
-Dennis
Most of us use anaconda to install pandas / etc. which is typically a pretty stable way to do it. Although perhaps the issue is also there with conda: https://github.com/ContinuumIO/anaconda-issues/issues/6678
There seem to be multiple discussions of this error on the web (e.g. https://stackoverflow.com/questions/40845304/runtimewarning-numpy-dtype-size-changed-may-indicate-binary-incompatibility/51587845) but none really seem related to matminer itself
Anubhav
import matminer
-Dennis
