I am very new to LAMMPS, and taking my first steps in MD with it. I wanted to try to simulate the thermal expansion coefficient of Al in a simple way, using the basic features of LAMMPS.
The basic idea was to create a loop which, at each step :
l Uses the fix box/relax under 1 bar pressure to let itself expand freely in later operations
l Performs a NPT run from Tn to Tn+1, under a fixed pressure of 1.0 bar
l After reaching Tn+1, minimzes its energy (with a fix box/relax to expand freely), to reach its most stable configuration at that temperature
l Computes temperature and volume and exports them to a file
I would have expected this to result in the following : as the value of Tn+1 gets higher and higher, the most stable lattice constant reached after energy minimization should have been larger and large, effectively reproducing the thermal dilatation.
However, what I observe is even simpler : nothing chqnges. The volume remains constant for all temperatures.
What is the problem here ? What is the reason why my simulation fails to reproduce thermal expansion in this simple way ?
My input scritp is given below.
Many thanks in advance !
shell rm data_alpha
print “Timestep |||| Temperature |||| atomic volume” append data_alpha
#------------ units ----------------------
atom_style atomic
timestep 0.005
#------------ lattice ----------------------
variable lattice_constant equal 4.025
lattice fcc ${lattice_constant}
region box block 0 1 0 1 0 1
create_box 1 box
create_atoms 1 box
#------------ potential ----------------------
pair_style eam/alloy
pair_coeff * * Al_mm.eam.fs Al
mass 1 26.98
#------------- variables&export ----------
dump 1 all custom 1 dump.* mass type xs ys zs
variable N equal atoms
variable atomic_volume equal vol/$N
variable T equal temp
variable time equal step
variable Tstart equal 200
variable Tstop equal 800
variable Titer equal 20
variable Tincrement equal $((v_Tstop-v_Tstart)/v_Titer)
run 0
#------------loop to get data on different temperatures--------
label loopTemp
variable i loop ${Titer}
variable startingT equal ${Tstart}+(i-1)*{Tincrement}
variable currentT equal ${Tstart}+i*{Tincrement}
NPT run to reach a given temperature
fix 1 all box/relax iso 1.0
fix NPT_fix all npt temp {startingT} {currentT} 0.008 iso 1.0 1.0 10000
dump_modify 1 every 2500
run 5000
minimize energy at the given temperature
minimize 1.0e-25 1.0e-25 5000 10000
print “${time} T {atomic_volume}” append data_alpha
#------------closing the loop--------
next i
jump SELF loopTemp
发送自 Windows 10 版邮件应用
