Invalid force field file format" in LAMMPS.
Thank you for your help in advance.
Jenny
Jenny
When I use a small test input:
units real
atom_style charge
region box block -5 5 -5 5 -5 5
create_box 1 box
pair_style reaxff NULL
pair_coeff * * ffield.reaxff.CrOFeSCH Cr
I get the following error message:
ERROR on proc 0: ffield.reaxff.CrOFeSCH:71: Invalid force field file format (src/REAXFF/reaxff_ffield.cpp:584)
Which means the invalid format is in line 71 of the file.
That line reads:
10.0000 2.5000 4.0000 0.0000 0.0000 5.00009999.9999 0.0000
Which is causing the issue due to joining two columns (5.000
and 9999.9999
). That would work with a Fortran program using an explicit format, but breaks the force field reader in a C/C++ code like LAMMPS. You can easily fix this issue by changing the problematic line to something like this:
10.0000 2.5000 4.0000 0.0000 0.0000 5.0000 9999.999 0.0000
This is part of an entry for an element X that is bogus anyway.
Great! This is indeed the problem, thank you!
